Additional Key Fob
Stanley Crewell
Stanley Crewell
Stanley
Springfield, VA
Bronco, Mountaineer, Mustang
" this procedure works only if the spare key programming is enabled. "
How do I check this, I just got my new FOB and tried to program it several times, only to get a message on the dash that programming failed :(
Also, make sure all Fobs are face down when you do the programming.
Ducati1098
You can’t. It’s enabled unless a dealership has disabled it, which is unlikely
joeb
Joe
Pennsylvania
FJ Cruiser
Any of the Fobs on Amazon can be programmed as long as you have the 2 original fobs using the instructions in the manual. I did it.
vicorjh
Jay
New England
2023 Bronco Wildtrack
thank you, I just tried it to no avail
Don't give up.
It took multiple attempts myself. I thought the key programming was set to disabled at first.
Follow the sequence posted earlier precisely. It sometimes can be difficult to tell if your in accessory mode or time-out wait mode when hitting the on/off switch.
If the programming is successful, a bunch of lights will flash and the display will tell you it's been programmed.
Stanley Crewell
Stanley Crewell
Stanley
Springfield, VA
I got two of these from Amazon and both them were easy to program and work perfectly.
Keyless Entry Remote Key Fob, Alliskeys Smart Proximity Key Replacement for Ford Lincoln 4 Buttons M3N-A2C93142600 902MHz https://a.co/d/4nX32cG
cbrenthus
Western PA
'22 BadSquatch, '02 T/A
Don't give up.
Thank you, I'll try a few more times. However, I get a message that "Key Program Failed" or something, which tells me I'm doing the sequence correctly, but it is not able to program the new key.
cbrenthus
Western PA
cbrenthus
Western PA
I did a search to see the difference and realize the only difference in the FCC ID is two zeros at the end, therefore I think the one I got is correct. I'll try several more times to program. I only got this FOB so I can have a 3rd stashed away in case I lose one. I've programmed several fobs over the years, and never needed 2 other fobs, although the other cars I got remotes for all had keys ('99 sebring, '98 trans am, '02 trans am, '08 element).
Pop
unknown
2019 Ranger
I just purchased an additional key fob (4 button like original) from Amazon. It appeared to program ok, got the message on the display that " Programming Successful ". The new key fob proximity feature unlocks the doors upon touch and the Start works, but the fob buttons to lock/unlock etc do not function. Any ideas out there. Maybe I need to purchase the key from Ford?? Thanks
Stanley Crewell
Stanley Crewell
Stanley
Springfield, VA
Possibly try programming them again. After I programmed mine they were both fully functional.
Pop
unknown
2019 Ranger
Gave it another try. Message displayed Max number of keys programmed. Still no button functionality. There's probably someway to reset. I guess I'll just keep the fob. I got incase I lose one.
old goat
Raul
Collin Co. Texas
Chevy Colorado
what if one is lost and only one left that I have . how do you program a new new FOB ) ?
