Adding weight, which lift system?
Sloth
SWFL
2022 Bronco
I'm looking to add a lift to my 22 Bronco Wildtrack (Hoss 2.0). So far I have added ~470lbs of weight to the chassis between bumper/winch and full skids/sliders. Could I run the standard springs that come on a Bilstein 6112/Eibach Stage2 or should I go for something with heavier springs like the kits from Old Man Emu or Dobinsons? I'll be hitting some trails through the southeast and want to build it right the first time. Nothing too extreme. Just want to build it right the first time.
Bumper/winch- 160lbs
Full skids (engine/trans/fuel)- 175lbs
Sliders- 135lbs
Extra weight- 470 lbs
Rkgzx9leftcoast
Robert
Scottsdale AZ
Jeep JL
If you look through the Eibach Stage 1-2 Thread There is some info of others with the same issue. I believe a few have done the Eibach stage 2 with different springs /rate on the front to get back some of the sag with the extra Weight.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
There is very little information on added weight overlanding setups. A couple of people have gone Old Man Emu and 1 person bought Dobinson rear springs. At a minimum you want some form of adjustable shock body when you start swapping springs which would eliminate OME. Its hard to help you since no one has gone full Dobinson on here yet and Eibach is more of a nice riding daily driver setup.
