Adding Tube steps later question
msg
2022 Wildtrak
I like the look to the tube steps, and also they should help the dog getting in on he own but I may not be able to get a Bronco that has them factory installed. How hard is it to buy something OEM/after market and put it on?
Thank you!
ET13
Honda
Not hard at all in regards to tube steps.
msg
2022 Wildtrak
Thanks!
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
Thank you!
It is so easy to install. I have a F150 that I literally bolted and unbolted (I ended up not liking them) in 30 minutes.
Dayton1984
Brandon
Dayton
2017 Acura RDX
Thank you!
checkout IAG steps, those look decent and can hook up to the factory rock rails.
geronika
OKC
53 Ford Pickup
I bought some from Havoc and they are tighten four bolts and you're done.
IAG Support
Wesminster, MD
Thank you!
We have a few different styles that quickly and easily hook right onto the factory rock rails.
https://www.iagperformance.com/iag-full-length-ez-step-add-on-for-2021-ford-bronco-1-pair/
https://www.iagperformance.com/iag-v1-ez-step-for-2021-ford-bronco-2-door-4-door/
https://www.iagperformance.com/iag-v2-ez-step-add-on-2021-ford-bronco-2-door-4-door/
dejones64
Dan
MN
Bronco 2-dr Black Diamond
TAC Side Steps 4” from Amazon. Under $200 for the 2-door.
Edit: if you have the OEM rock sliders you’ll have to remove them to use these side steps. These can be installed without any assistance.
Ford Bronco Adding Tube steps later question 34A010B9-9B86-4DD6-8957-E96C446F5AF2
Ford Bronco Adding Tube steps later question BC3FAB22-7A91-4EAC-B079-46BB8A86E0ED
Dayton1984
Brandon
Dayton
2017 Acura RDX
They really are terrible. The cut of your leg pretty good regularly.
A smoother finish is a must, and then being so high is awkward.
oh dang, sorry to hear. I have just seen pictures and some other comments from people that seemed to like them.
Thanks for the heads up. I plan on the heritage standard or Wildtrak with factory steps myself.
Theowlhoothoot
DFW Texas
Model 3 Performance
We need them for one kid but will dump them as soon as she grows more. If you go steps just get some electronics ones and call it a day. The factory ones weren’t that great either, but they didn’t tear up our legs.
HBTFD
Newnan GA
F350
Not hard to install. A 2nd set of hands helps but not necessary. They really help deflecting rocks off the front tires.
