Adding light switch with fog light option
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Damn I paid $77.28 years ago.
My part # was M2DZ-11654-DA though. That site you linked (Ruxer) sells the one I got for $81.90
So mine clearly has additional functions
Ford Bronco Adding light switch with fog light option 1732674655239-ju
PorpoiseBlue
Mercedes, TX
Ram 1500 Laramine
I paid 74 for the switch with both the front and rear fogs!
I use the rear switch to switch my front fogs to amber.
Ford Bronco Adding light switch with fog light option 1732675285713-s2
Chrome_Pony
Chrome
The Great Land
Have one sitting in the garage I took out of my 23 Badlands High to replace with the dual F/R foglight switch... that I'll eventually get around to wiring a use for.
M2DT-13D061-DDW
Ford Bronco Adding light switch with fog light option 1732687494936-ol
Ford Bronco Adding light switch with fog light option 1732687513340-io
flip
Phil
IN
www.ruxerparts.com
Fords
Here's a list of all the switch choices. Basically, you look up what is on the vehicle according to HVBOM or parts catalogue, then find the one with the same options and "front fog lamps". In 2021 there weren't nearly as many choices, supersessions and build date breaks.
If you've set up an account on our parts store, sent me a DM with the email addy you used, I put you in the 6G discount group so the price you see below from the catalogue is list, not what you will see on www.ruxerparts.com.
Ford Bronco Adding light switch with fog light option 1732709811032-9y
Ford Bronco Adding light switch with fog light option 1732709840053-7x
Ford Bronco Adding light switch with fog light option 1732709878666-vx
Ford Bronco Adding light switch with fog light option 1732709907616-5s
Ford Bronco Adding light switch with fog light option 1732709936966-h
maunman2
Philip
Wilmore, KY
2022 Bronco Badlands MT SAS, 2011 Toyota Tacoma, 2024 Land Rover Defender 90
@flip, you’re a kind gentleman for offering us all a discount. I will set up an account soon.
I currently have a -HC style switch since I have spots and puddle lamps but no fog lamps in my Badlands High w/modular bumper. Do you know if a person could buy a -AC switch and swap the bezel with their original bezel that has the spot buttons? Would the puddle lamps be a problem even if you could swap bezels?
Thanks,
A fellow Flip
EDIT: I stumbled onto the answer to my question. Per this post, one cannot buy a headlamp switch module without spot switches (the lights on the mirrors that are part of the zone lighting group) and swap the bezel in order to retain their old spot switches:
https://www.bronco6g.com/forum/threads/factory-fog-light-switch.22937/post-1733008
AzGrayHeritage
Keevan
Georgia
Azure Gray Heritage 24
Don't mean to hijack but I have this switch, can I swap out in my Heritage and and use this for adding lights?
Ford Bronco Adding light switch with fog light option PXL_20241201_145904325
Dugout
Joel
ETX
24 Bronco
If anyone still checks this post, do you need a special wiring harness for added fogs lights on modular bumper?
Ford Bronco Adding light switch with fog light option 1756315137417-wz
@4x4TruckLEDs.com same guy sending you an email.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
If your truck is a 2024 or earlier and you have front sensors, then the pigtail is in your bumper near the tow hook. You can use one of our pigtails and fog kits (you'll need to buy your own switch panel and program the circuit via forscan)
If you have a 2025+ then you have no pigtail in the bumper and you need to buy a new harness (i don't know part #'s but scroll up, someone else does)
