Adding Fog Lights to Badlands (Modular Bumper)
Virtual-Chris
Virtual-Chris
North Vancouver
From the looks and shape of the modular bumper the BD kit should work much like the Raptor kit, only a little smaller overall. And the aux switches are very likely to be the same. Learned a lot doing this project. This is my setup with an additional 10in BD ON MY 2018 and excited to reuse with new brackets on my new Bronco. I am thinking, only one of the Squadron Pro cubes and the smaller one will fit Bronco. Use the other squadron Pro spot cube up by the mirrors since they so kindly provided a space just for that!
I‘d be interested in your review of the kit in terms of practical uses and scenarios where it can come in handy, light output, etc. It certainly looks cool.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
I put these Rigid Industries pods on my 2015 Silverado - The OEM fog lights were awful. These were 1000x better and well worth it. I'd love if I could do something similar with my modular bumper on the Bronco. I like the pictures above from the Raptor!
Ford Bronco Adding Fog Lights to Badlands (Modular Bumper) BF4D4A8E-9ACA-4BCA-85AF-CA3E7E3DCFAD
Sighlense
Upstate NY
2015 Mustang GT - 2022 Bronco Wildtrak
timhood
Tim
Several
I am not sure about the switch but it would be nice if it did support fog lights.
Rigid makes a nice setup for the Raptor. I emailed them and they will have a solution for the Bronco this summer. The Raptor setup has 3 lights per side
Link to those, so I can get an idea?
timhood
Tim
Several
That’s true @5280Bronco . I meant on my truck that turning the lights off unlatched the relay for the fog lights. Being on the overhead switch, they should turn back on when the switch is turned on, which I would prefer 95% of the time.
Your headlights don't have an automatic feature?
We leave our headlights on "auto" and the fog lights go on and off with the headlights. There's a separate button to turn them on/off manually, but no need to use it.
BlazinGTO
Dustin
MA
2004 GTO M6 2004 Escape
The problem with the pod lights mounted like the Raptor is that you lose the ability to remove the bumper end caps for extra clearance. It will leave the lights severely exposed to damage off road.
If someone is okay with that, then its the best area for fogs.
One solution is to have a pocket cut in the bumper and flush mount the lights. Some manufacturers offer a kit for flush mounting.
I think im going to mount them on the top of the bumper where the bull bar would attach. Not the most ideal spot, it could be lower and further to the corners, but I think I'll like the look.
Erock
US
2018 F150 Alpine edition
Yeah, they have an auto... but I never use em.
Bigkansas
AUSTIN
Topeka ks
If they mount to the bottom piece that is removable, and have a wiring disconnect there. Itd work i think. Remove the lights with the end piece at once.....That was what i was hoping for.
Tonka1
Brad
Green Bay, Wisconsin
Jeep Wrangler Willys
What determines if the fogs are included on the BL? Is it part of a specific package? I don’t recall and can’t find the answer. TIA
The fog lights are excluded on the BL bumper.
JHawk
Ray
Heartland, USA
Fusion Sport
timhood
Tim
Several
JHawk
Ray
Heartland, USA
Fusion Sport
It's not clear by the description. Does the mount kit include the brackets for both sides?
I believe it does include both sides. The description states that is is fits 6 D-series lights....3 per side
Ford Bronco Adding Fog Lights to Badlands (Modular Bumper) Capture420
5280Bronco
Denver
I know those integrated kits look really good, but I'm going to go old school with the round fog lights. Just saw the BL bronco racing in Mexico right now has lights right where i want to mount mine on the modular bumper. Looks like some brackets are attached to the stock bumper bolts and the lights are attached to that. Hopefully someone makes a bracket just like it for sale.
Ford Bronco Adding Fog Lights to Badlands (Modular Bumper) 20210427_115357
peterh
ny
jeep wrangler jlu 2018
This times a million! ideally, I'd like to also see a super simple straight(ish) bumper, maybe a stubby!?
5280Bronco
Denver
Here's a different angle that i completely missed before.
Ford Bronco Adding Fog Lights to Badlands (Modular Bumper) 20210427_132549
