- Adam
- Aug 30, 2021
- 555
- 6,159
- 7,050
- Lindenhurst, NY
- Website
- www.4x4TruckLEDs.com
- 2018 Raptor & 2021 Bronco Outer Banks
- Outer Banks
We've got some new products from Addictive Desert Designs we'd like to share with everybody. I think everybody will LOVE these killer new products they've come up with. We plan to outfit our entire Bronco with all of their new accessories.
Addictive Desert Designs Overhead Molle Panel for 2021+ Ford Bronco
https://www.4x4truckleds.com/addictive-desert-designs-overhead-molle-panel-for-2021-ford-bronco/
The 6th Gen Bronco Overhead Molle Panels provide versatile storage options and easy access to your gear. One panel spans between the driver and passenger seats, while a perpendicular panel runs behind the seats. This strategic layout ensures that your essential items are always within reach, even while you're comfortably seated. The molle pattern is compatible with a variety of attachment solutions. Whether you prefer straps, bolts, Quick Fists, or other compatible accessories, you can securely fasten your pouches, tools, and digital devices in a way that suits your needs.
Items can also be stored on the top of the panels due to their 90-degree radius edges. This design ensures that your stored items remain in place even during sharp turns or rough terrain. Our panels are expertly crafted to conform to the body lines of the roll bars while providing ample space above for headroom. Strategic cutouts in the molle provide access to the hard top latches, allowing you to remove or install your hard top while the panels are installed. Installation is straightforward as these bolt directly to the roll bars. As always, these are made in America.
Addictive Desert Designs Tailgate Molle Panel for 2021+ Ford Bronco
https://www.4x4truckleds.com/addictive-desert-designs-tailgate-molle-panel-for-2021-ford-bronco/
The 6th Gen Bronco Tailgate Molle Panel maximizes storage options in your vehicle's cargo area. Crafted from â…›-inch American steel, this panel is built to withstand the toughest terrains. Its robust construction ensures that it maintains rigidity even during bumpy rides, providing a secure platform for all your gear. The hammer black powder coat finish not only adds a sleek and stylish look but also protects the panel from rust and corrosion.
With our versatile Molle pattern, you have the freedom to mount a wide range of equipment and accessories. From recovery gear to pouches, first aid kits to tools, or even a fire extinguisher; you can customize the panel to suit your needs. It is compatible with various attachment systems like straps, bolts, quick-fists, and zip ties that gives you flexibility in securing your gear. The wide mounting points keep the panel snugly in place, while the horizontal offset protects your vehicle's paint from contacting the panel. As always, this is fully bolt-on and made in America.
Addictive Desert Designs Rear Window Molle Storage Panel for 2021+ Ford Bronco (Pair)
https://www.4x4truckleds.com/addict...olle-storage-panel-for-2021-ford-bronco-pair/
The 6th Gen Bronco Rear Window Molle Storage Panels offer a convenient and organized storage solution. Our molle panels allows you to securely attach various gear and accessory mounts. The flexibility in mounting options means you can strap, bolt, or clip items onto the sturdy panels. Whether you need to store tools, first aid kits, recovery gear, or other essentials, these panels keep everything within easy reach.
Our molle panels were designed to provide a perfect fit around the Bronco’s rear roll bars & seat belts for a polished look. They can be used with or without a hardtop, eliminating the need to reconfigure your cargo storage every time you remove your top. Our panels have sturdy and reinforced mounting points to effectively eliminate rattling sounds while also providing the strength needed to carry your gear. The use of existing factory accessory mounting locations & factory mounting hardware means that no modifications are required for installation. As always, this is fully bolt-on and Made in America.
Addictive Desert Designs Digital Device Dash Mount for 2021+ Ford Bronco
https://www.4x4truckleds.com/addict...gital-device-dash-mount-for-2021-ford-bronco/
The 6th Gen Bronco Digital Device Dash Plate utilizes OEM accessory mounting locations, and provides a versatile surface for mounting your digital devices. Compatible with Ram Mounts, this plate helps you organize your devices at arms reach. It is perfect for smartphones, action cameras, GPS, radio, tablet, and more. At the center of the plate are dual USB ports for models that do not include factory USB ports.
This heavy-duty steel plate was designed to fit flush with the factory bodylines of your Bronco’s interior. The device mounting points feature PEM nuts to easily install your device holders using 10-24 accessory bolts. As always, this is fully bolt-on and Made in America.
Addictive Desert Designs Center Console Molle Panels for 2021+ Ford Bronco (Pair)
https://www.4x4truckleds.com/addict...nsole-molle-panels-for-2021-ford-bronco-pair/
The 6th Gen Bronco Center Console introduces convenient storage options that allow you to keep your essentials organized and within arm’s reach. Located on the top of both panels are 8 PEM Nuts that are compatible with RAM diamond-based digital device mounts as well as other common brands. This lets you easily install your device holders using 10-24 accessory bolts. Our panels are perfect for stowing molle pouches, handheld radios, a multi-tool, sheaths, holsters, EDC gear, and many other Molle-compatible accessories. The dual panel design keeps a clean looking interior and preserves full access to OEM controls and handles. Installation requires minor drilling but does not require dash disassembly. As always, our products are made in America.
