F1NDx
Detroit, MI
@Bigmoose dumb question but - do these only work when it’s dark out? Just did it and programmed it but they’re not turning on
Bigmoose
Bigmoose
Jon
RI
2019 Flex Ecoboost Limited
Good question. Most likely. Just throw a towel over the ambient light sensor on the dash
Bigmoose
Bigmoose
Jon
RI
Did you get this working?
F1NDx
Detroit, MI
Nope! I’m not sure what is going wrong. Lights work. Tested on upfitters. Triple checked my Forscan changes… also feels like I skipped a step haha. I have. 2021 non-Sas Base 7MT if that makes any difference. Any insight is much appreciated!
Bigmoose
Bigmoose
Jon
RI
Take a picture of the wiring at the door modules and post it up.
F1NDx
Detroit, MI
@Bigmoose I pulled the pin but I have a red arrow going to where I had it. Also made a dumbed down diagram of what I did (minus Forscan changes)
Bigmoose
Bigmoose
Jon
RI
So i assume you have a good ground since you wired the “red” connections to an upfitter and it worked. Are you sure you have the pin set properly in the connector for the door module? If the wire is too thick it wont go all the way in. If you look at the connector when it is disconnected you should see your new pin flush with the housing like all the others.
Pugsly
Clayton, DE
2014 Ford Fusion
Does anyone know the part number of the Lux mirror with the puddle light built into it?
atlawson
Tracy
Rose Hill, VA
Bronco 2022 Wildtrack Lux w/ Sasquatch
This was shared with me a few months back on another thread for a LUX model.
Ducati1098 said:
The part numbers I originally posted were for everything in this picture with a small yellow square next to it…
The mirror cap cover (green in the picture) which isn’t included:
LH: M2DZ-17D743-D
RH: M2DZ-17D742-D
The mirror arm cover (yellow in the picture) also not included:
LH: M2DZ-17A703-B
RH: M2DZ-17A703-A
Pugsly
Clayton, DE
2014 Ford Fusion
Ford Bronco Added Puddle Lights to my Mid Package BD side mirrors! (Video added) 2d6e29c6-6400-4282-83c0-11a0cd15d863-jpe
LH: M2DZ-17D743-D
RH: M2DZ-17D742-D
LH: M2DZ-17A703-B
RH: M2DZ-17A703-A
Ok, thanks you all.
Bigmoose
Bigmoose
Jon
RI
Ok, thanks you all.
Fyi those are not plug and play on the mid package wiring harness. You will need to add wires to the door modules for puddle and side lights.
Skott
Missouri
2022 Bronco
Waiting for someone to do this, and write it up.
I'd like an idiot-proof walkthrough that gives me the stock look of those turn signal indicators and puddle lights, for my mid package WT.
EilersPark
Hans
Leander, Tx
2012 Dodge Ram 1500 4x4
I got the Oracle puddle lights for thier mirror cover ditch lights and really want to get this figured out. After reading this thread I get the general idea of how to do it but would like an easy way to get this done with detailed step by step instructions.
Hungy13
Greg
Pa
2023 Bronco
Probably a dumb question here, but will this approach work at all without Forscan programming? Would the puddle lights go on at all? Or would they stay on while the ignition is on? Etc…. My BD is 3 months old and I’m afraid using Forscan for anything would void the warranty. Thx.
