ACC Delete kit?
JoeSpeed
Eatontown, Jersey
2dr 2.3 Manual
  • Thread starter
  • Banned
  • #1
Long story short, I got badlands as I wanted mid+stick, but unfortunately it also comes with Co-pilot.
Might already have the answer with Forscan, just disable a lot of the crap, but afterwards it's taking the little black box sandwiched between the intercooler and removing it, or just getting a different bumper without it and the cameras. Just wondering if there's anyone out there who's working on a solution that doesn't include either or one or the other.
Thanks in advance
BlueBronco
DFW
Within the Bronco menu settings you should just be able to turn off the acc and set cruise to normal. This is how it is on my F150. However, I think there are other systems such as crash alert that rely on that radar and I don't know if those are able to be disabled.
I actually had my BL in the garage today and pulled off that little plastic cover. This is a high package so no acc. However, behind the cover was a larger piece of molded plastic and behind that was a wire harness and maybe a module plugged into it. Not sure how much the lux package will differ or if the radar will screw onto the plastic housing below.
Ford Bronco ACC Delete kit? PXL_20210815_160816852
Ford Bronco ACC Delete kit? PXL_20210815_155942070
Note that the piece of plastic above is one larger molded piece that includes the housing for the shutters.
Edit. Reread your post and see you are a mid package so no acc. However, everything still applies and what you see is what you will be getting in your BL.
2Jeeps&PatriotX1
Denver, CO
Mid package doesn't include the ACC. Have to step up to lux to get the ACC.
GoTigersGoBronco
Zachary
Memphis
Toyota 4Runner
Is automatic emergency braking radar or camera based. I know on most cars it uses a camera at the rear view mirror. I don't believe the adaptive cruise control radar system impacts AEB.
BlueBronco
DFW
Lucky for you I don't have much going on today. This took less than 10 minutes to strip down. Large plastic House does not contain any sensors. Just the servo motors for the shutters. So this can definitely be discarded on packages from high on down without reason for concern.
Ford Bronco ACC Delete kit? PXL_20210815_204650225
Ford Bronco ACC Delete kit? PXL_20210815_204503175
Ford Bronco ACC Delete kit? PXL_20210815_204920050
Ford Bronco ACC Delete kit? PXL_20210815_205143522
Ford Bronco ACC Delete kit? PXL_20210815_205134108
Ford Bronco ACC Delete kit? PXL_20210815_205139819
Ford Bronco ACC Delete kit? PXL_20210815_210248081
BlueBronco
DFW
Also, these pigtails are right where the fog lights are on other models so I think all models have wirings for fogs and maybe we can just swap out our main switch. @flip do you have a part number for the light switch that contains the fog light's?
Ford Bronco ACC Delete kit? PXL_20210815_205815996
Edit. Damn autocorrect.
JoeSpeed
JoeSpeed
Eatontown, Jersey
2dr 2.3 Manual
  • Thread starter
  • Banned
  • #7
Thank God.
Definitely deleting the grille shutters and its servo then, wanna get as much air into the Intercooler as possible
flip
Phil
IN
www.ruxerparts.com
Fords
Also, these pigtails are right where the dog lights are on other models so I think all models have wirings for dogs and maybe we can just swap out our main switch. @flip do you have a part number for the light switch that contains the fog light's?
I’ll check tomorrow
AHop
Adam
Minnesota
'73 F250 Highboy, '96 Miata M-Edition
Looks like the fog light connectors according to the wiring diagrams. However, you would also have to program the BCM to accept the input from the other headlamp switch. It is ultimately the BCM that controls those lights, not the switch itself.
Jug
DFW
2021 F150
I'm sure there will be plenty of upgrades for the intercoolers. Here is one for the Ranger 2.3L
Ford Bronco ACC Delete kit? 1629063171894
flip
Phil
IN
www.ruxerparts.com
Fords
rtaylor
R
ID
19Raptor, 22Bronco
The manual says that AEB uses the safety camera, but it also uses radar if equiped.
I would buy the LUX package if I knew for sure that the radar features could be disabled (ACC/EvasiveSteer/AEB+). Even better if Ford makes the radar features a separate package from LUX for MY2022.
WuNgUn
Ontario Canada
2 door Squatched
Thanks in advance
You spent all that money on Lux to get....? An extra USB plug and wireless charger? Lol
