AC air is not very cold
Brad
New Hampshire
2017 Ford Focus RS, 2022 Hyundai Palisade, 2001 MV Agusta F4 750
I have a 2024 Wildtrak, and the AC isn't very cold. The air is still a bit warm until I turn it all the way down to "Lo". Doesn't seem to make a difference if it is on recirculate mode or not. Anyone else have this issue?
Every spring I have to add about half a can of refrigerant and then it blows cold all summer long
Something to check
Bill K
Allen, TX
Ford Bronco Big Bend 2 Door
Something to check
I'm glad I have the equipment left over from the battle with my wife's Honda CRV new refrigerant system issues. When mine starts blowing a little warm, I guess I'll be adding with the Bronco too.
ChrisB351
Shreveport, LA
Make sure the AC button is turned on (lit)
Techun
Pa
BD, 2.7, MIC, 4dr
Something to check
You have a leak to fix.
Definitely not normal for a vehicle this new. I find the AC blows extremely cold (for front passengers...)
thesocalexplorer
Southern California
My 22 blows ice cold, colder than any of my previous toyotas (which were my previous gold standard).
I'd take a listen to your HVAC blend doors to hear if anything is snagging and bringing hot air into the mix. That, and get the refrigerant level topped off.
OBX_SAS_2021
Charlie
Did you check if the cabin air filter is clean?
Fast Eddie
Ed
NY
2025 4Dr OBX, 2025 Navigator BL
I work in auto service. Youd be surprised how many times I see it.
Lol. I too have been a victim of something like this. Took my wife's truck in for regular service and told them the rear lift gate would not power open or close. Picked the truck up later that day and they said it's fixed, they pushed the button in the overhead console to turn the power feature on. I felt duuuumb.
tommy5sheds
Thom
Washington
2023 Bronco Sasquatch
I had my ac go out on a cross country drive. The belt shredded at about 25,000 miles on my base squatch with a 2.3.
CarmeloS
Carmelo
Central Jersey
Happens a lot with Fords, I had it happen on my old Mustang and current Bronco, and my bro had it happen on his '15 GT
Get it done while its still under warranty, or just done in general
You are not wrong - but right now it’s cheaper to top off than dive in and try to fix it
Brad
New Hampshire
More to the story... Took it to a dealer, and they couldn't find anything wrong. They said the tech said it was blowing at 35 degrees. Must have been Celsius, as it doesn't get anywhere near that cold in Fahrenheit! I checked it with a very accurate chef thermometer in my vents, with the air set on 67 degrees, and my thermometer shows 92 degrees! When I set it to Lo, it blew 59 degrees. Seems to be a massive difference in actual temp for just 7 degree change on ac dial. Guess I'll try another dealer
Ford Bronco AC air is not very cold 1778359673300-md
Seems like for the fancy temp systems there is a temp sensor down by the drivers side knee that loves to have issues and feeds back to the hvac to tell it the cabin temp
92F may as well be heater running
