ABS light just came on. Help
tandd6
Tiny
ABS light and collision detection systems unavailable and other lights in dash just lite up for no reason. 2025 Big Bend. Help
Ford Bronco ABS light just came on. Help IMG_0427
Ford Bronco ABS light just came on. Help IMG_0426
Gene Dios
Atlanta
Have you been offroading or going through water at all?
The abs sensor connections in the rear can get gunk in them and cause this. Unclip them and have a look
tandd6
Tiny
Hill Start Assist failure as well
heavy rain no real water
SledDog30
Bob
colorado
Time for a trip to the dealer, if it’s under warranty.
Sandy56
Tennessee
2022 Outer Banks Sasquatch
Magic ball says…. try again later (just go to the dealership)
SledDog30
Bob
colorado
Be sure to post the solution. I’m curious to find out what the issue could be.
tandd6
Tiny
So I drove it home and about 10 miles into the drive it all just went back to normal so my guess is it was the rain getting something wet but I went ahead and made an appointment with the dealer
You need to see the DTC code
there are hundreds of possible causes do those lights. While there are definitely some repeat offenders, not every case is the same
Odds are you just had some excessive wheel slip in the rain and the Bronco interpreted that as a potential broken axle — this is fairly common and once reset, everything is fine. Just an overly vigilant computer check. Low or failing battery is another common cause and easily fixed with an overnight on a trickle charger. Dirty or damaged wheel speed sensor another common offender.
But if you pull the DTC code with a OBD reader - we won’t be sitting around just guessing. If you don’t have a scan tool often auto parts stores will read them for free.
