Superchips_Mktg
Jacob
Sanford, FL
www.holley.com
2022 Bronco
We are pleased to announce that we've expanded coverage of the popular 1546 Flashcal for Bronco to include 2024 model year support! Flashcal makes taking control of your Bronco's features and options easy, through our simple, menu driven, handheld interface. Plug the Flashcal in and you'll be making changes in no time. No looking up codes, referencing forums, etc.
Check out this list of available features and options:
• Speedometer adjust for Tire Size 28.25 - 36.25"
• Fog Lights: enable "Bambi Mode" for simultaneous use of fog lights with high-beams
• Headlamps Position Setting: option for headlamps to return to "Auto Lamps" or remain at last known position
• Auto Lights Delay: duration headlights illuminate after driver exit, 0, 5, 10, 20, 60, or 120 s.
• Daytime Running Light disable or enable
• TPMS Disable, for off-road wheels and tires
• Independent TPMS threshold: Front and rear axles can be set differently from 1- 90 psi.
• Silent Mode: Turns off most cabin and exterior lights, and door chime with open door, ignition chime remains
• Honk Warning Disable: 2-honk warning when driver exits running vehicle with key fob
• Lock Feedback Lights: Enables hazard blink with unlock command
• Auto Unlock: Vehicle unlocks with ignition off
• Auto Lock: Disables factory setting to lock doors when vehicle is in motion
• Auto Relock: Disables factory setting to re-lock doors 45 seconds after unlocking
• Remote Unlock: Option to trigger all doors or just driver door
• Remote Start: Selects engine run time duration for 0, 5, 10, 15 mins
Ford Bronco 2024 Bronco Now Supported on Flashcal 1546! SC_24_Bronco_Flashcal_release_2560x675_01
https://www.holley.com/products/tun...andheld_tuners/superchips_flashcal/parts/1546
mb86gt
Matt
KC
06 Silverado
Any updates on when auto start/stop disable will work on 23-24 models?
buzpro
Binky
Tacoma
Are the listed options a sample? can it do more?
Arokcrwlr
Kraig
US - Alabama
2014 F150, 2014 Focus, 1973 Bronco
Is a SW update available to update an existing FlashCal? Link?
ejaffe
New Jersey
Audi TT
Seems a little pricey considering Forscan is free and the connector is only $60. Plus with Forscan you get more opportunities to customize. What am I missing?
Arokcrwlr
Kraig
US - Alabama
You got it. I won one in a drawing and it never worked on my 23. I can't get an answer if there is a SW update for the thing - my only interest in this thread.
Epiphany
Upstate
'24 Bronco
No auto start/stop disable?
zjtr10
Odessa Texas
2001 Dutch Star , 2024 Bronco
I’ll buy one as soon as it can disable the ASS feature
huey
kevin
Ontario & Kentucky
VW GTI VW EOS GMC Envoy Badlands Bronco
ford dropped rev matching?
@Brian_B It is currently working, if I plug in to adjust a setting will it kill an existing rev match setting
There's a lot of discussion about it on the 2024 ProCal 50 State Approved thread.
From what I have heard - '23 and '24 models lose the ability to have ASS memory and rev matching. I currently have them, I haven't updated my ProCal since I installed it last year though - and I'm not about to go try it out to see what happens.
If you already have it, you can keep it - so long as you DO NOT update ProCal online. Basically don't plug the dongle back into the computer.
I do not think there is a way on ProCal to revert to older tunes - once you "update" to the latest, you are stuck -- short of someone at Ford Performance going in and helping you out.
Which kind of sucks, since you kinda have to do that if you want to use it to upgrade your front axle. Steering rack you can get around, but not sure how to get around the FAD delete without ProCal and doing an update.
Superchips_Mktg
Superchips_Mktg
Jacob
Sanford, FL
www.holley.com
2022 Bronco
The Flashcal can easily be updated in the field if you have one that needs to be updated to work in newer models as we release coverage.
Ford changed the way the auto start/stop works for 23+.
Update any existing 1546 with our Update Agent software on a PC or Mac, and it will work on the 2024 models.
You can d/l it from this page:
https://www.holley.com/support/tuners/superchips/
Superchips_Mktg
Superchips_Mktg
Jacob
Sanford, FL
www.holley.com
2022 Bronco
For many people, Forscan can be more than they want to deal with. Here's a video from one users perspective.
