codeseven4918
Calgary
2021 Honda Accord 2.0
I will say these were easy and straightforward to install. I wanted something affordable up front to keep all the garbage on our roads off the paint while I work on getting some decent steps. I don’t think I like the way they extend past the stock fender flares and can see myself upgrading them in the next few months.
Ford Bronco IAG I Line Front Mud Flaps Installed IMG_0121
Ford Bronco IAG I Line Front Mud Flaps Installed IMG_0119
Ford Bronco IAG I Line Front Mud Flaps Installed IMG_0120
Ride Em Bronco
Al
Pittsburgh, PA
2024 2-door 6-Speed Manual Big Bend Bronco
This photo is copied from the IAG website - and the front mudflaps don't appear to be protruding out from the fender flares.
Ford Bronco IAG I Line Front Mud Flaps Installed 1721579062326-iq
codeseven4918
codeseven4918
Calgary
Thanks! That looks like the Sasquatch flare though, but more of the look I was hoping for.
Something Wild
KC, MO
2023 Badlands
I've installed the same, front and rear. Fronts were a real life saver driving down gravel roads back at my parents. Even with, still have rock chips in the rear flares, but would have been much worse without the guards. Really came in handy running into some deep mud ruts at a local OHV park this weekend. Overall I'd say well worth it and they look good.
Dugout
Joel
ETX
24 Bronco
My Mabett flaps don’t stick out and do their job well.
Ford Bronco IAG I Line Front Mud Flaps Installed image
GroovyGeek
Boyan
'23 Bronco BD
The IAG mini mudflaps for use with vehicles that have factory rock rails fits the bill better for me. Here’s how they look on my truck.
While these look much better they provide close to zero protection on gravel roads. Were one of the first purchases I made, took the bronco on some back roads and heard "tink tink tink" as pebbles were hitting the side panels. Could feel them hitting my hand as I lowered it. Sold for a 50% loss immediately.
The IAG I line is Chinese imports of non critical goods that are meaningfully more expensive than what these things could be bought for from Chinese vendors on Amazon.
PS perhaps in combination with your side steps they do a better job
Dreamer
Kevin
Connecticut
Ford Mustang GT convertible
The found the side steps that attach onto the rock rails definitely help reduce the amount of rocks hitting the vehicle. I’ve driven on many dirt and gravel roads, and have few nicks in the paint. The bottom of the sides steps, however, show the wear and tear of gravel road. They were great together.
timhood
Tim
Several
At first look, I thought those were identical to the Ford OEM ones I got, but I see now that I went and took a look, they are slightly different.
Ford Bronco IAG I Line Front Mud Flaps Installed tempImageJPIMlZ
codeseven4918
codeseven4918
Calgary
Thanks for that! After seeing how the OEM ones stick out they’re starting to grow on me a little. Ripped down a gravel road yesterday and didn’t hear one ping which I also like.
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
Yeah it's definitely designed more for the SAS flares. But still looks fine to me on your vehicle. I have MAbettt ones and they look exactly the same. Mine have been on for almost 2 years now and have held up very well. My bolts are all rusty though.
Swacer
PA
2022 Raptor; 2018 Shelby GT350; 2023 Bronco
I use Rokblokz on both my F150 Raptor and the Bronco. Both have it protruding out the sides about an inch or two to cover the exposed tire (stock wheels, so no additional offset). Neither truck has any rock chips on the fender flares. They have worked really well, you especially hear it during the winter as salt gets flung around and smacks the flap instead of my paint.
Desert_6G
Phoenix, AZ
Ranger
I found my Mabett catch the lugs on my tires near full lock. not sure if I installed them wrong because of the poor black and white directions that were provided that looked liked they were printed with a 100 dpi resolution or if the rubbing is normal?
Dugout
Joel
ETX
24 Bronco
Just did a 360 both directions in a parking lot no sounds from my front mudflaps. I’ll send some pics of my install and I should have the color copy of my instructions. I got with mine. Hope that helps. I’ll send stuff later today. @Desert_6G
Dugout
Joel
ETX
24 Bronco
Here is mine installed on stock sas bdlands rims/tired. Hope this helps.
Ford Bronco IAG I Line Front Mud Flaps Installed IMG_2680
Ford Bronco IAG I Line Front Mud Flaps Installed IMG_2681
