LastDeadLast
Shannon
2023 Black Diamond, 1965 Mustang Convertible
Hey Folks!
I've had my 23 Black Diamond 2 door for about 4 months now and am loving it so far. The most major gripe I have about it is the lack of really any meaningful storage outside of the rear cargo area. I started looking for hard cases that might fit in the same area and I stumbled across the Pelican Vault V700. It fits like it was made for the space and effectively raises the rear storage area up about 6 inches.
I found the case on Amazon for $170, so it's pretty cheap compared to other solutions. I think I might apply some kind-of-a anti-slide layer to the top if I can find something reasonable. If anyone has any ideas, please fire away.
-s
Ford Bronco 2 Door Rear Storage Solution - Hard Case (Pelican Vault V700) 20240316_165543
Ford Bronco 2 Door Rear Storage Solution - Hard Case (Pelican Vault V700) 20240316_165523
LastDeadLast
LastDeadLast
Shannon
Golfsnob,
That's a nice setup, but I need the back seat, so I can't go that route. Great for camping trips though!
What is the material you have on the bottom of your shelf?
-s
GlueBoy
gluefactoryoffroad.com
21 Bronco
I was in the same place and didn't see any panels that worked with or without the hardtop so I made my own molle and started selling them.
I just got back from Moab and was able strap all the recovery gear and tools with the cargo hooks, then keep all first aid, tire repair, and my fire extinguisher up and out of the way. Gotta get creative with the two door.
Ford Bronco 2 Door Rear Storage Solution - Hard Case (Pelican Vault V700) 20240312_150137
Poppavein
Redmond, WA
Harleys, Ducatis, 2024 Bronco
Skateboard tape.
LastDeadLast
LastDeadLast
Shannon
Golfsnob
St Augustine
2023 Base 2 Door, Manual, 2.3
Golfsnob,
-s
It's a cheap quilted faux leather mat I found on Amazon that just happened to be the exact measurements of my sliding tray.
SHANUT
Craig
Hermann, MO
Hey Folks!
-s
Could you share the link? Thanks
BCKMRKR
James
NorCal
'22 Wildtrak 2-Door, '19 Miata, '15 M235i
Tool chest drawer liner which you can buy by the roll? Definitely tacky enough, though not sure how well it holds up to heat inside a car.
Dialtone
Twilight Zone
Bronco Big Bend Mid
Hey Folks!
I've had my 23 Black Diamond 2 door for about 4 months now and am loving it so far. The most major grip I have about it is the lack of really any meaningful storage outside of the rear cargo area. I started looking for hard cases that might fit in the same area and I stumbled across the Pelican Vault V700. It fits like it was made for the space and effectively raises the rear storage area up about 6 inches.
-s
For cheap you could add some Command Strips and tool drawer or waffled shelf liner to the top.
If you want something more permanent use 3M Super 77.
4dtrkman
Russ
Kingsport TN
F150 / Edge
Where did you find the slide drawer ?
