IAG Off-Road
JJ
Westminster, MD
www.iagperformance.com
We are excited to announce that the long-awaited AUX switch kits are now available! If your Bronco did not come with factory AUX switches, or you simply need to add more, this kit is a great option that has everything you will need all in one package. Featuring an 8-panel switch on a made-in-house bracket designed to mount in an easily accessible spot up on the dash, you have plenty of outputs for everything from lighting, winches, compressors, and more. Everything needed to complete the installation is included in the kit from hardware to brackets to wiring!
Ford Bronco New IAG Product Release: Aux Switch Kit and Mounting Brackets 1709582821645
Moving under the hood, the fuse panel and circuit breakers are mounted on two more made-in-house brackets that use existing factory mounting points. No drilling is required!
Ford Bronco New IAG Product Release: Aux Switch Kit and Mounting Brackets 1709583014718 Ford Bronco New IAG Product Release: Aux Switch Kit and Mounting Brackets 1709582992303
These AUX switches are offered in two different versions either with or without Bluetooth. The Bluetooth version has a phone-based app, that allows you to control the button operation directly from your cell phone within Bluetooth range. This could be used when you are outside of the truck or if you want to hide the switch panel in the truck and just use the app for turning on accessories.
Bigred86
Curt
Thurmont, Maryland
2022 Ford Bronco, 2016 Harley Davidson Sportster48
This is cool! Ya all are always comming up with good stuff. Thank you for supporting our platform!
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
That's cool - I like the addition of the Bluetooth control as well. Nice accessory!
GroovyGeek
Boyan
'23 Bronco BD
That would be a slam dunk purchase for anyone who does not have the factory switches.
A slight missed opportunity is to make the in-cabin mount dual function - aux switch plus left hand phone mount.
@IAG Performance is that mounting bracket available for standalone order?
HarveyBirbman
Harry
Ashburn, VA
Bronco 22'
Very cool product. Does this require updating the fuse box like you would if you wanted to install the factory switches?
Big Boss
Outer Heaven
Bronco Big Bend
Yes!!!!!!!
Ford Bronco New IAG Product Release: Aux Switch Kit and Mounting Brackets IMG_20240305_085613
Spender
Ontario, Canada
Bronco, Edge
Any chance you would sell the hardware kit parts separately for those of us who already have AuxBeam? Mostly interested in the under hood mounts since I went the quick route and velcro'd to the fuse cover claiming I would revisit (and have yet to do so).
Peitnahtan
Nathan
Los Angeles
N/A
Any update on the Hidden Compressor kit?
IAG Off-Road
IAG Off-Road
JJ
Westminster, MD
We are moving forward with that kit quite well. Our current goal is to release in Mid-April at Super Celebration East.
IAG Off-Road
IAG Off-Road
JJ
Westminster, MD
It does not! This is a completely standalone system.
mikec426
Russellville, AR
22 4dr Sqtch, '04 Yam FZ1, 22 Versys 1k, 19 Ninja
Does the ignition need to be on to operate accessories? I have your interior light kit (not installed yet), but don’t want it tied to the doors opening. I just want extra light when I need it.
IAG Off-Road
IAG Off-Road
JJ
Westminster, MD
There is a 12v trigger wire to turn on the fuse box. If you wanted to you could hook that up to a constant 12v source, you would just need to make sure you turn everything off manually. Out of the box we have you tie into an ignition source for turn on so that there is no danger of killing your battery.
