tj@steeda
TJ
Pompano Beach, FL
2019 Mustang GT - White Carbon Edition
With the twin-turbo 2.7L that you find in the Broncos, there's a lot of air being pushed through that stock exhaust. Open up that restrictive factory exhaust with a 3" mandrel-bent system from Thermal R&D. With both a mid-mounted muffler and another in the rear, this exhaust opens up the tone and flow without adding drone thanks to a true Helmholtz resonator. This particular system has a black ceramic-coated muffler and optional tip, which can be left off for more ground clearance as well. There's a lot to like about this system so check it out here!
https://www.steeda.com/thermal-r-d-b911-c911-c-bronco-cat-back-exhaust-system-black
Fly by Nite
Walt
Pa
Nice job on the video! (tho I skipped directly to the sound clips). Very helpful to hear the difference between stock and aftermarket exhausts, especially the drive-by's.
Another sponsor rated the Thermal as one of the quieter systems. What other systems do you offer that are also quiet(er)?
I did check out your vids on Youtube of other Bronco systems, sure helps to do the comparisons.
Wish you would do a video of the cat-back Borla Touring system, that's one that is often recommended here. It's at the same price point as the Thermal.
JL8jeff
Ewing, NJ
It looks like this is for the 4 door only but I don't see any reference to that if it is.
nolimits
23 Badlands
Where are the dyno results? If you are going to claim “max power gains” then back it up.
Fly by Nite
Walt
Pa
Altitude
Howard
Papillion, NE
2015 Grand Cherokee, 2008 Suzuki B-King
Not a fan of that dip in HP / TQ below 3.7k, which is interesting to me. I understand that with NA cars you want some back pressure to help with cylinder scavenging, but I was always under the impression that with forced induction less back pressure is always better. Can anyone explain why a freer flowing exhaust would reduce low end power in this application?
JL8jeff
Ewing, NJ
In the video they talked about how that truck was Roush tuned and I think with the intake. So the hp increase from the exhaust probably doesn't represent a stock truck difference. The other tuning might have moved the power curve up higher resulting in the loss lower. It does seem like a lot of trucks that have parts upgrades are being used for different power upgrades in the dyno tests so it can be really tough to know how the modification would behave on a stock truck.
2023bronco
location
vehicles
In the real world, i.e., street/highway, I want power from off-idle to say 4,500 rpm. I'm not drag racing and hanging out at 5,000+ rpm.
Bigfx
The modern day engine for the most part is pretty optimized, unless you are adding more fuel or boost there really isn’t any power increase. The truth is none of this “power adders” do anything other than shift the power band at the very best unless it’s an actual tune. Removing restrictions or optimizing flow only really shine when you tune for it. Every manufacturer claims their product does “x” but it doesn’t period. We buy the parts because they are cool and we like to work on our vehicles. So with that being said enjoy the extra noise and try not to look too deep into it lol.
TopRamenGod
2023 Bronco Wildtrak
Might be an ignorant question, but do installs like these affect the warranty of the vehicle?
BeerRunner
Luke
Seabrook, TX
2023 Bronco
Great video, love the comparisons. Would love to know the hp/tq increases on a bone stock bronco vs the roush intake ;)
Yeah shame all that effort and not on a stock bronco
SHANUT
Craig
Hermann, MO
Most people drive below 3000 RPMs, so anything that could potentially reduce power below there would be a huge waste of money. I’ve seen other devices in the market that actually reduce your horsepower at lower RPMs which is crazy to me.
