85 ° vs HI. Temp ?
joeb
Pennsylvania
FJ Cruiser
Wondering what the temperature difference is when you turn knob past 85°. When it says HI -- What is the actual temperature.
Anyone have the facts?
Thanks
Haelous
US
2016 Mustang GT, 2023 Bronco Wildtrak
Hi and Lo just go full blast heat or cold. That's how it is in my Mustang too.
Haelous
US
There is no actual temp. It just goes full heat or full cold forever.
330SMG
Dennis
Hurricane Alley
16 F150 ,89 325i and 72 Dodge Charger SE
Whatever the temperature is of the air passing through the heater core. It is not regulated by climate computer.
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
Take an infrared thermometer and let us know your findings.
The temperature stated does not match the temperature of the air coming out the vent. The temp stated is the targeted cabin air temperature.
Whether you ask it for 19°C or 25°C it’ll blast full heat as needed to get you there and then back off. Especially when it’s -30 outside.
joeb
Pennsylvania
FJ Cruiser
Will do
Thanks
Gramd
Graham
Airdrie, Alberta
2022 Bronco, 66 Chevy ll
It’s potentially as hot as your coolant will get
PrepVet
North Central WI
A bunch.
My Fan speed does not change. I understand it goes full heat, but is it hotter than 85° ?
The temp here isn't controlling the fans, but it just ignores the thermostat. Basically at HI, yes it can potentially get hotter than 85, as the heater core is just going to keep dumping heat into the system. I'm not sure what Ford has the internal limit set at but, in theory, it could keep pumping heat roughly equal to the engine temp as the heater core is cycling the coolant through it.
joeb
Pennsylvania
FJ Cruiser
Ok. Makes sense.
Thanks
Figmo
Figmo
Frenchtown, MT USA
Suzuki Samurai, Bronco 2Dr WT, Gladiator Rubicon
"Hi" on the heat setting means "1966 degrees or however hot your engine gets" (whichever comes first)
