Switchworks_Kyle
Kyle
Oxnard California
2022 Ford Bronco
Introducing our NEW Bronco mounting kits for the Alpha12 Digital Smart Switcher system! These kits offer a seamless integration solution for controlling all your 12v accessories. With a mounting plate for the brain and a grab handle mounting kit, you can effortlessly incorporate the Alpha12 into your setup.
The Alpha12 by SSV Works is a groundbreaking digital accessory switcher, unlike anything you've seen before. It boasts 12 fully programmable outputs, all conveniently controlled by an LCD push-button display featuring customizable icons. Each button even has its own LCD screen behind the actual push-button, allowing you to easily switch between the 60+ preloaded icons or upload your own.
But that's not all – because each button is digital, the Alpha12 provides real-time voltage and amperage draw per circuit, right at your fingertips. No need for an app, as all the setup menus are accessible through the buttons themselves. Experience ultimate convenience and control.
These are just a few of the many features of Alpha12! For more detailed information on the Alpha12, click the link HERE. And if you're a member of the Bronco6G Forum, don't forget to message us for an exclusive discount. Be sure to add the Bronco mounting kit after adding Alpha12 to your cart to get the complete kit. Upgrade your setup today with the Alpha12 Bronco mounting kits!
Ford Bronco SwitchWorks Alpha12 Digital Smart Switcher ae35f267-a04b-4ead-81a6-5c76a0ec16fd
Ford Bronco SwitchWorks Alpha12 Digital Smart Switcher c71f5082-e9f1-4471-928a-882718a11aa9
Ford Bronco SwitchWorks Alpha12 Digital Smart Switcher 9adbfd3d-2f11-405c-b91c-bc247eba3b40
Ford Bronco SwitchWorks Alpha12 Digital Smart Switcher 7393060d-785d-45ee-b02a-2b73c6388eb1
Ford Bronco SwitchWorks Alpha12 Digital Smart Switcher d8e69073-d3f4-470e-9a54-671608f58c6e
Ford Bronco SwitchWorks Alpha12 Digital Smart Switcher 8eaa0f8d-0776-468d-92a0-56c9b9d53656
Ford Bronco SwitchWorks Alpha12 Digital Smart Switcher 4a4e915c-3dc7-4e93-b1d6-f584962df85d
Draughon
Daylon
Dallas
BMW 4-Series
Neat!
Expensive as hell....but neat.
DBC Offroad
Sean
Reno, NV
www.youtube.com
'23 Raptor
Looks cool. Is there any integration with the Pre-wired locations Ford put in the Bronco for the Aux Switches? Or would you just have to run new wiring?
Thanks!
Switchworks_Kyle
Switchworks_Kyle
Kyle
Oxnard California
2022 Ford Bronco
Neat!
Thanks!
Hello,
You could connect your Aux switches to our kit though, you would just need to wire them direct to the brain. For instance on our Bronco we did connect the power Aux switch from the bronco to the brain to power it on/off. It's entirely up to you how you would want to have the kit work for your needs.
Feel free to call our customer service team if you have more questions, they are in-house and very knowledgable. 818-991-1778, you can ask for James.
I can also send you a discount code if you are ready to make the purchase, just let me know!
Thank you!
Switchworks_Kyle
Switchworks_Kyle
Kyle
Oxnard California
2022 Ford Bronco
Agreed, but I would like this a lot in my PW and get rid of the hodge podge of switched i have now.
You won't be disappointed in the kit and you can DM me for a discount code for it too!
It looks awesome - I am looking for an upfitter switch solution, but this is a bit much for my needs (both in number of switches and especially price point). I can't even think of what to use 12 switches for, although I'm sure there is a market for it.
Maybe it's just caveman me, but I still think of this when I think of aux switch:
Ford Bronco SwitchWorks Alpha12 Digital Smart Switcher 1701992133180
Switchworks_Kyle
Switchworks_Kyle
Kyle
Oxnard California
2022 Ford Bronco
Totally understand, the kit is not for everyone. You would be surprised how quickly you can fill up the outputs. If you are running say rear pods, you can have a left and a right and same for the fronts, that's 4 outputs right there.
Let us know if you have any questions, happy to help out!
Thank you!
mikec426
Russellville, AR
22 4dr Sqtch, '04 Yam FZ1, 22 Versys 1k, 19 Ninja
And there’s really just something kinda cool about that type of switch.
BAJA FORGED
Johnson Valley, Ca
www.bajaforged.com
2021 Ford Bronco, 1968 Ford Bronco
The Alpha 12 is awesome. We have installed two of these in Broncos and love the features they offer. It really makes the installation process easy, and the functionality of the control panel is super fun. It gives you of ton of options, and creative ways to work your components.
Cardboardbronco
Cb
Socal
Mustang
May be a silly question but I see this kit and some others mount directly on the fuse box. Do you have to remove it if you ever need to open the fuse box or can it still be opened with the module on top. Thanks
Tye
Tye
San Francisco
Porsche GT3, Landrover Defender V8, BMW X3 Msport
You should consider making an 8 switch version as well to compete against the switchpros sp-9100. Not everyone needs 12 channels and with the sp-9100 costing almost half the price, its hard to not consider it. If u had an 8 channel version at a $750 price point, i think you would garner more interest.
Switchworks_Kyle
Switchworks_Kyle
Kyle
Oxnard California
2022 Ford Bronco
Hello,
This kit uses Solid State technology, so it eliminates the need for fuses and relays going forward. The Module(Brain) will sit in your engine bay, the accessories(power and ground) crimp into the pig tails that run directly to the brain, and that's it!
Take a look at the link below and it will give you a lot more info on the kit. It is loaded with features and we try to make this a clean and simple usage kit for consumers. Its amazing!
https://ssvworks.com/collections/sw...lpha12-digital-smart-switcher-with-12-outputs
Please let us know if you have any other questions, Thank you!
Switchworks_Kyle
Switchworks_Kyle
Kyle
Oxnard California
2022 Ford Bronco
Hello Tye,
Yes we are working on a smaller version, unfortunately it will not utilize the same digital screen. It will be more of a rocker switch type of system but will hit a much lower price point. I will be sure to update on Bronco6G when we are launching this new product.
Thank you!
Tye
Tye
San Francisco
Hello Tye,
Thank you!
Why cant it be made to utilize the screen?
