Metal-tech 4x4
Oregon
21'+ 22" Broncos, Lexus GX470, Toyota FJ40
The Metal-tech 4x4 rear swing-out bumper is now open for orders! $500 off for all pre-orders shipping in Sept. This bumper has been in development and testing for over a year. It can carry up to a 40" spare 100% off your back door and frame mounted. Optional twin Nato fuel can racks on either side of the center-mounted tire to carry 11 gallons of fuel/water.
Featuring CNC machined soft shackle mounting points that you pick the color you wish, we then custom Cerakote them in-house for you. Cerakoting is an incredibly durable ceramic finish.
Use code: REAR500 for $500 for your pre-order.
More photos and info on our website: metaltech4x4.com
Ford Bronco Rear swing-out bumpers are now taking orders!  $500 off promo.   Get that tire off your back door and carry 11gal more fuel! Bronco_rear_3__74390
Ford Bronco Rear swing-out bumpers are now taking orders!  $500 off promo.   Get that tire off your back door and carry 11gal more fuel! bronco_rear_open-jpg
Ford Bronco Rear swing-out bumpers are now taking orders!  $500 off promo.   Get that tire off your back door and carry 11gal more fuel! Swing_arm__90118
Ford Bronco Rear swing-out bumpers are now taking orders!  $500 off promo.   Get that tire off your back door and carry 11gal more fuel! Bronco_rear_4__83366
Ford Bronco Rear swing-out bumpers are now taking orders!  $500 off promo.   Get that tire off your back door and carry 11gal more fuel! 5__34242
Ford Bronco Rear swing-out bumpers are now taking orders!  $500 off promo.   Get that tire off your back door and carry 11gal more fuel! 4__96061
Ford Bronco Rear swing-out bumpers are now taking orders!  $500 off promo.   Get that tire off your back door and carry 11gal more fuel! 8__24589
Ford Bronco Rear swing-out bumpers are now taking orders!  $500 off promo.   Get that tire off your back door and carry 11gal more fuel! 5__84354
UPDATED WITH MORE INFO:
One single back door from Ford = one single swing out with a 120lbs gas strut to assist.
Two swingouts for a truck with a single door will always require the operator to open and close that second swing, no option. It may not sound like much, but from customer feedback over the years (Metal-tech 4x4 has been building swingout bumpers over the past 20yrs. ), and from our own use, it just is a bit of a PITA. Also, on the trail or in camp, when the back is open, both sides of your truck are now blocked. Mimicking the swing of the OEM rear door simplifies access and overall use.
Now to support and accommodate a large single swing, yes, that takes quite a bit of development to do it right. Starting with the Toyota FJ Cruiser back in 07' we did exactly this. The evolution of that swing-out system, both what is seen and not seen, is now on every one of our single swing systems, like the Lexus GX470 and GX460 (also with a single large swinging rear door).
  • 100% custom CNC machined spindle featuring two serviceable tapered radial bearings top and bottom with the proper seal. (Never bushings/heim joints/raw bolt or pin)
  • 1.75" cold rolled CNC machined steel pivot welded in double shear in the bumper.
  • Replaceable stainless latch rotated 45* so it pulls down and back, not just one plane. Also, 100% bolted on and able to be serviced over time.
  • Swingout landing pad on the latch side features replaceable CNC machined UHMW wear pads, so there is never steel on steel.
  • Frame mounting system that not only uses available 12mm mounting bolts but also goes over the top of the frame using drawbolts, boxing how the bumper is mounted for rigidity of loads.
  • Reinforced internal structure to support the swing-out loads and accommodate pull points in line with the frame for proper recovery loading.
The list goes on, and these are just some of the key needs for a proper swingout.
Dmorty217
Derek
Venice FL
Camery
Do you have any pictures of it opened?
Metal-tech 4x4
Metal-tech 4x4
Oregon
35tires
'23 Bronco, '21 4Runner
Wait that is just one huge swing out piece? Not two sections? Holy moly.
RC Bronco
Rob
Kansas
'22 Ford Bronco, '97 Geo Tracker
I like it, but I’m too poor right now
MayhemMike
Mercury
I’d be first in line f the Bronco tailgate operated like a pick up truck. Looks great, nice job.
Metal-tech 4x4
Metal-tech 4x4
Oregon
100%!
Valhalla
Valhalla
Chattanooga Tn
Nothing against this product at all, and it looks great. Love the double jerry can, however, I hate opening a gate then opening a gate... I haven't needed a Jerry can off road yet. my longest trip was 53 miles of rough terrain used a quarter tank. If i needed it, it would be something along these lines.
lakesinai
Charleston SC
About the same as operating my Kuat Pivot bike rack!
Ford Bronco Rear swing-out bumpers are now taking orders!  $500 off promo.   Get that tire off your back door and carry 11gal more fuel! SmartSelect_20220105-191141_Gallery
CalvinT
Calvin
Phoenix, AZ
What about the backup camera? Need an extension cable for it. Or is one included? Can't tell from the photos.
