Freebird32
Harold
97 F150 4x4, 82 Toyota 4x4 orig owner, 08 Z06
Those definitely look like spot welds. Adhesive/sealant was used on the plate to ensure no leakage. Structural adhesive on such a small area wouldn’t be sufficient to sustain design load.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
cr117
PNW
Bronco, EV6
Good luck getting a warranty claim. If you do try taking it back to the dealership, whatever you do, do not mention anything about your diy roof rack.
indio22
Chicagoland, USA
Installed a 175Lb rooftop tent on top of my diy rack.
Bouncing through a hole, popped the plug welded plate off.
Someone had to find the limits 😆
Is it possible the area was contaminated by wax, hence the failure? ;)
Seriously though, that concerns me, as I plan to have various boats mounted on top at highway speeds. For me the weight won't be an issue, but would not want a mount breaking loose and have the boats and all fly up or break loose.
tock13
Tony
WA State
Mazda, 66 Honda CT90, ‘94 Toyota Xtra cab
I think those mounting points were designed by the same team of 1st years that designed that genius rear hatch on the soft too.
Can’t wait to see other discoveries pop up to shake a head at.
TomH
CT
Ridgeline, 2023 Badlands
swamp2
I've got a thread on the rack. Myn was too tall, wasn't sure on height clearance around the soft top at first. Will be going lower for less lever action.
Your rack design is the fundamental problem, very unlikely the vehicle. The lack of rear torsional support placed too much load into the front mounting points.
There are plenty of Broncos with racks and RTTs that combined weigh way more than the measly dynamic 100 lb load limit I have heard of. These folks wheel hard with no problems.
cr117
PNW
Bronco, EV6
Exactly. Way too much torque on those windshield mounting points. You can't just bolt on things and expect it to support all that weight swaying and bouncing back and forth and expect it to hold. The flaw was in the design of the rack.
indio22
Chicagoland, USA
Is there a photo of the rack in this thread? I didn't see one.
Malicar
Malicar
Jessy
Prince George, British Columbia, Canada
2022 Bronco
I agree on the problem.
The height of the racks front blocks were main issue though. Torque is increased further out you are.
Rear of the rack was fine, had turnbuckles installed. No sway/torsion.
Rear is what kept everything sturdy enough to drive home.
I've seen quite a few broncos with rtt as well. Haven't seen any of them wheel their's with the rtt and gear on though.
swamp2
I disagree on your view of the problem. No matter how stiff you tried to make it, a single center (and) hitch mount for a roof rack will permit too much torsion of the rack. That leads to the large tension and compression loads at the front corners, of which the tension clearly caused your issue.
Do you doubt a Bronco can wheel hard with a traditional multi-point roof rack and attachment system on a hard top? I've not personally seen one do so myself, but I have full confidence folks have and do so without issue.
His design....
Ford Bronco . IMG_20230701_095420
