Status
Not open for further replies.
WickedG6
Georgia
2022 Bronco, 2021 4Runner, 1967 Mustang 2+2
New solution to cargo management and off-road organization. I've designed the Packhorse to provide 4-door Bronco owners with a heavy duty and dependable sliding cargo option. The Packhorse turns your cargo area into 100% usable space for gear, tools or A LOT of groceries. This innovative design allows full access to your cargo storage compartments and turns them into secured, hidden storage by adding a security lock. The base model includes CNC laser cut mounting points built right in to make adding additional baskets, custom equipment mounts and molle panels a snap. All steel construction and finished in a fine textured, black powder coat come standard with optional colors available. Looking for a custom mount to fit on the Packhorse accessory points? We can design those for you as well. Discounts are active for all Packhorse orders placed during June 2023.
Visit our website at wickedrelicsoffroad.com
Ford Bronco The Packhorse - Expandable Cargo Solution IMG_4389
Blackcat
South Carolina
2022 FORD BRONCO BASE 2 DOOR M/T
How long are those drawer slides and what's the wight capacity? Forgive me if you said in the video, I don't have sound on my PC.
WickedG6
WickedG6
Georgia
Also, you have full access to the storage and jack compartment in the floor of your cargo area.
dadjoke
Southern California
'22 Bronco Big Bend 4-Door 2.7 MIC Auto Sasquatch
Hey OP Can you make the link in your original post a little more visible? Thank you!
Mad Martigan
Matt
Oklahoma
Fords (Bronco BadTrak, Expedition Timberline, Bronco Sport, Edge ST)
Do you know if this will mount/fit inside the Ford cargo enclosure? It looks like it might?
WickedG6
WickedG6
Georgia
I have not tried the fit but I could check into it and get back with you. There is about 3/4” of an inch clearance in the sides and about 1” clearance around the back to give you an idea of the fitment.
doyouglas
Douglas
Southern California
Toyota Highlander
This is a nice cheaper solution compared to the diabolical slide floor.
Will there be clearance to close the rear door if they have a tailgate table?
Mad Martigan
Matt
Oklahoma
Thank you!! I think the back would be fine as the enclosure back panel only comes down the floor for the second seats.
The enclosure sides are pretty close to the edges of the cargo area but I’ll get measurements tonight.
WickedG6
WickedG6
Georgia
Plenty of room for tailgate tables, molle panels, etc. to clear.
WickedG6
WickedG6
Georgia
Yes please, let me know about the clearance. The mounts have about 1/2" of adjustability on each side but I would need to make the tray a custom width for you. But that is easily done. Just contact me via website and we can get it taken care of. wickedrelicsoffroad.com
WickedG6
WickedG6
Georgia
Are you/ ya'll working on a lay flat top for it? Similar to the diabolical one.
Currently we are working on several accessories for the tray itself as well as additional gear mounts that fasten to the floor mounts to support baskets, molle panels and custom panels per customer requests. We do have an insert in the works for the tray that includes a table surface. Hope that helps. Reach out if you would like a custom accessory designed for you.
cracKen
Ken
Washington
23 Bronco Badlands 7MT
I like it. Just waiting on a flat top and somehow to bridge the gap between the rear seats folded down so I can sleep on top of it.
Status
