Metalcloak
Metalcloak
Rancho Cordova, CA
2021 Badlands Sasquatch
Front and Rear Skids are now available (and Shipping) from Metalcloak.com... All skids are laser cut from 3/16" Hot Rolled Steel and CNC formed for a perfect fit....
First are our new Front Lower Control Arm Skid Plates...
Ford Bronco Control Arm & Shock Skid Plates from Metalcloak 1685575790861
Ford Bronco Control Arm & Shock Skid Plates from Metalcloak 1685575840504
You can see our full line of Bronco 6G Products here...
Metalcloak
Metalcloak
Metalcloak
Rancho Cordova, CA
Metalcloak
Metalcloak
Metalcloak
Rancho Cordova, CA
HorizonHunter
Joseph
Chapel Hill, NC
Grand Cherokee Trailhawk
Metalcloak
Metalcloak
Metalcloak
Rancho Cordova, CA
You leaked your tie rods!
LOL... would be a great "spy pic"... if they hadn't been seen by tens of dozens at Wild Horses... as well as streamed online. ;-) - Matson
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
I understand that armor isn't a beauty pageant, but those are the best looking ones I've seen.
It is a beauty pageant for a mall crawler… They need this armour to look beautiful for the Starbucks parking lots they flex in.
ICUGAZN
Kevin
Woodbridge, Virginia
2019 Raptor
@Metalcloak Is it possible to get the LCA skids in regular zinc coating? Not gold? Thanks.
Metalcloak
Metalcloak
Metalcloak
Rancho Cordova, CA
Metalcloak
Metalcloak
Metalcloak
Rancho Cordova, CA
Unfortunately that is not possible. All our zinc coating is done with Gold Chromate. However, the gold is a surface protectant that can be removed with acetone and/or some cleaners... leaving the silver zinc finish behind. It also makes for a great painting surface if you want to custom colorize it.
Metalcloak
Metalcloak
Metalcloak
Rancho Cordova, CA
Gtrekker
Gary
NJ
Nice!!!! Waiting....👍👍
ICUGAZN
Kevin
2019 Raptor
Unfortunately that is not possible. All our zinc coating is done with Gold Chromate. However, the gold is a surface protectant that can be removed with acetate and some cleaners... leaving the silver zinc finish behind. It also makes for a great painting surface if you want to custom colorize it.
I guess it wouldn't look bad against the Aluminum skids? Also, I have Eibach coilovers that have 19mm nuts vice stock 18mm. Do you think that would be an issue? Thanks.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
I too thought I wouldn’t be into it - but, it sorta just blends in and doesn’t appear GOLD. I was attracted to how robust and clean the LTA skids were. Customer service was on point and I will buy more products when the time comes.
Ford Bronco Control Arm & Shock Skid Plates from Metalcloak IMG_4049
