- Bryan
- Aug 5, 2021
- 41
- 5,489
- 14,572
- New England
- Ford Bronco, Escape, Focus
- Badlands
Obviously this isn't the first video on this subject... BUT I couldn't find any videos that actually showed the kick panel speaker removal (the closest I found was this video). So to help people out who are completely new to this (and as a personal challenge to myself), I created a video for it.
If you've done speaker replacements before, this video probably goes into more detail than you need.
So... TL; DW—
Rear Pod Speaker Removal
So... TL; DW—
- Remove speaker grille with a trim removal tool. There will be (4) clips holding the grille on.
- Remove the speaker held on by (2) Phillips head screws
- Remove the speaker grille with a trim removal tool. There are (5) clips total holding the grille on.
- Remove the speaker held on by (2) 7mm screws
- Remove the (4) TP-30 "Bronco bolts" securing instrument panel grab handle to the vehicle.
- Remove the grab handle completely, there are (2) clips securing the rear of the grab handle to the panel.
- Remove the cowl side trim panel with a trim removal tool. There are (4) clips total securing the panel. Note that (2) of those clips are securing the bottom of the trim piece and are very difficult to remove.
- Remove the scuff plate trim panel to expose the cable tray with a trim removal tool. 4-door Bronco has (7) clips. 2-door has (9) clips total.
- [Driver Side Only] Release the dead-pedal
- Remove the dead-pedal trim cover with a trim removal tool. There are (6) clips total.
- Use a 10mm deep socket to remove the (2) nuts securing the dead-pedal to the vehicle
- Remove the speaker grille. There are (2) clips securing the speaker grille. These clips are along the forward edge (closest to front of vehicle) of the speaker grille. Do not pry from the rear edge of the grille.
- Remove the lower cowl side trim panel with a trim removal tool. There are (3) clips securing the panel.
- Remove the (3) 7mm screws to release the speaker.
- Kick Panel Speakers: Kicker KSC670
- Pod/Dash Speakers: Kicker KSC40
- Bass Blockers: Crutchfield 300 Hz cut-off
- Dash/Pod Harnesses: Hoel Wiring Bronco/Maverick Speaker Harness
- Kick Panel Harnesses: Metra 72-5602 4-Way Speaker Harness
- Kick Panel Mounts: Metra 82-5605 Mounting Brackets
