Status
Not open for further replies.
tomsoffroad76
TOMS
Medford, Oregon
2022 Ford Bronco
Ford Bronco TOMS OFFROAD | Dana Spicer - In Stock! LG-TOMS_6G_Forum_Banner_1__1_
TOMS OFFROAD has partnered with Dana Spicer to be the first to stock these drivetrain upgrades for your 6th Generation Ford Bronco.
Ford Bronco TOMS OFFROAD | Dana Spicer - In Stock! LG-Dana_Announcement_1
Available To Ship Today
Spicer Extreme Half Shaft Kit for Ultimate 44 AdvanTek FDU*, 21-23 Ford Bronco
  • 2021+ Bronco w/ M210 Front Axle 32 Spline
  • 32 splines for extreme durability and performance
  • Built by Dana, the leader in Ford Bronco drivetrain manufacturing
  • Larger CV bells & 35 spline center bar for added strength
  • Takes more torque and much more angle than factory shafts
  • *For use with Ultimate Dana 44 AdvanTEK Front Drive Unit upgrade.
Spicer Extreme Half Shaft Kit, M210 29 spline, 21-23 Ford Bronco
  • 2021+ Bronco w/ M210 Front Axle 29 Spline
  • 29 splines for extreme durability and performance
  • These half-shaft kits are a direct replacement, bolt-in installation that require no further modification.
Ultimate Dana 44 AdvanTek Front Drive Unit, 21-23 Ford Bronco
  • Dana-designed, cast-iron center housing allows for deep gear ratios that are not supported by the factory front drive unit to provide the perfect set up for your Bronco
  • 32-spline differential side gears provide improved strength for better off-road performance
  • Electronic locking differential offers optimal traction when you need it
  • Choose the best gear ratio for your Gen 6 Ford Bronco: First to arrive will be 4.88 and 5.38.
  • Fully loaded, ready to install to save time and money
  • FAD-eliminated solid axle tube for increased strength
  • Cast iron tube provides added strength over stock aluminum tube.
Bronco Parts Coming Soon - Stay Tuned
These parts are either in-transit to TOMS OFFROAD or they are on-order. Our partnership with Dana Spicer allows us to be the first to stock these items for your new Ford Bronco. We will give an update on this thread when each of these parts have arrived at our warehouse, so stay tuned!
Spicer Extreme Half Shaft Kit, M190 29 spline, 21-23 Ford Bronco
  • 2021+ Bronco w/ M190 Front Axle 29 Spline
Ultimate Dana 60 Semi-Float Axle
  • Double-row tapered roller axle bearings deliver crucial strength and weight capability
  • High-strength 35 spline chromoly axle shafts for durability and improved off-road performance
  • Nodular iron differential cover provides better protection from obstacles and an eye-catching design
  • Fully ABS compatible
  • 3 1/2" × 11/32" tubing and heavy-gauge brackets for added strength
  • Eaton E-locker
  • Gear Ratios on order: 4.88 and 5.38
___​
At TOMS OFFROAD, we strive to make your Bronco parts shopping experience the best around. From the Show Bronco build to the G.O.A.T. Bronco build, shopping for your early or new Bronco at TOMS OFFROAD you'll find yourself supported by fellow Bronco enthusiasts always ready to answer your technical questions or give experienced advice.
For more information and pricing, visit: https://tomsoffroad.com/ford/drivetrain---6g-bronco
Contact Us
Email [email protected] or Call 541-779-1339
Follow Us
YouTube: https://www.youtube.com/@TomsOffroad76
Instagram: https://www.instagram.com/tomsoffroad76/
Facebook: https://www.facebook.com/tomsoffroad76
LinkedIn: https://www.linkedin.com/company/tomsoffroad76/
Resources
Visit https://tomsoffroad.com/ to find installation instructions, instructional videos, and schematics. You can also sign up for our newsletter to be the first to know about deals, events, and TOMS OFFROAD news.
Figmo
Figmo
Frenchtown, MT USA
Suzuki Samurai, Bronco 2Dr WT, Gladiator Rubicon
Get thee behind me, Satan!
Just when my wallet is starting to recover - you gotta wave this steak under the nose of a starving man. Guess I‘m gonna have to put in a few more overtime shifts still.
Gabby
Gabriella
Milwaukee
22' Bronco, 16 Tiger 800XCx, 96 Duc 900SS/Sp
So the rear comes with an electronic locker system. What happens if I don't have the factory electronic locker? Is there a wire bundle I can buy to add it in via one of my aux switches?
Atoledo95
Alan
Los Angeles, CA
2022 Ford Bronco Outerbanks
  • Eaton E-locker
___​
Contact Us
Follow Us
Resources
When is the Dana 60 going to be available? Please and thank you.
Neps
Floating off California
MX-5 30th, Focus EV, F150, Scout II (2)
Yes, you'll be able to connect to aux switches or install a seperate switch.
mike8675309
Minnesota
It's available with an ARB locker also. They may not stock it, but it's available from Spicer.
If I were going with 40's these parts would be on my list to support that size and weight of tire if I was regularly going offroad.
orion
Jeremy
17' F-250, 17' Explorer
Why the he'll does shite have to be so expensive these days!!! 😡🤬😤😠😣😖😞☹🙁😟😧😦🥺😫😭
If I was single, I would sell my house and live in my 5th wheel and then have the equivalent of the APG Pro Runner and doing Mischief Maker shite! 🤪
Gabby
Gabriella
Milwaukee
Thank you! I wasn't aware some of them were ARB compatible. I just wanted them for the locker since it looks simpler than doing the ARB air locker on the OEM setup.
mike8675309
Minnesota
Valhalla
Valhalla
Chattanooga Tn
32 SPLINE!!! WHERE IS THE 50 FROM THE RAPTOR AND IT'S SHAFTS OR ARE THE 32'S THEM? (sorry for the yelling, I'm at work and one of the apps makes caps come on and I'm lazy).
Atoledo95
Alan
Los Angeles, CA
  • Eaton E-locker
___​
Contact Us
Follow Us
Resources
This would be ok with broncos without Sasquatch correct??
Before I order 😂
mpeugeot
@tomsoffroad76 can you get my 4.27:1 gears for my M190 that aren't welded to the carrier? Any other gearing options? I want to install a truetrac lsd in my non-sasquatch Bronco.
mpeugeot
Before I order 😂
I think that you would be looking for the half-shafts for the M190, UNLESS you have a non-sasquatch Badlands.
Atoledo95
Alan
Los Angeles, CA
I meant for the Dana 44 fdu
I wanna replace it complete
I have a non sas outerbanks and then also buy the shafts
Status
