orion
Jeremy
17' F-250, 17' Explorer
Thanks. I've saved aux 1 for the locker. Is your aux switch just a relay or powering the locker itself?
Straight to the locker. If you do that, use AUX 1, I would change out the fuse to a 10 amp. That is what the wiring harness for an aftermarket e locker uses.
tomsoffroad76
tomsoffroad76
TOMS
Medford, Oregon
2022 Ford Bronco
The first shipment of the Ultimate DANA 60s are currently in transit to our warehouse! When our listing is live, Bronco6G will be the first to know!
Shop 2021+ Bronco Parts https://tomsoffroad.com/ford/2021-ford-bronco-parts
Contact Us
Email [email protected] or Call 541-779-1339
Follow Us
YouTube: https://www.youtube.com/@TomsOffroad76
Instagram: https://www.instagram.com/tomsoffroad76/
Facebook: https://www.facebook.com/tomsoffroad76
LinkedIn: https://www.linkedin.com/company/tomsoffroad76/
tomsoffroad76
tomsoffroad76
TOMS
Medford, Oregon
2022 Ford Bronco
In case you missed it on our social platforms (@tomsoffroad76 ), the Ultimate Dana 60 Rear Axles have arrived, with more on the way!
The Ultimate Dana 60™ Semi-Float axle is now available from TOMS OFFROAD for the new Bronco! The Ultimate Dana 60™ is a BOLT IN replacement featuring Spicer® chromoly steel axle shafts, Spicer ring and pinion gearing, heavy duty brackets, Dana nodular iron diff cover and more.
Ultimate Dana 60™ Semi-Float Axles for the Ford® Bronco® Features and Benefits
  • Double-row tapered roller axle bearings deliver crucial strength and weight capability
  • High-strength 35 spline chromoly axle shafts for durability
  • Electronic or air locking differential offers optimal traction when you need it
  • Choose the best gear ratio for your Gen 6 Ford Bronco
Dana Eaton E-Locker Part Numbers: UD60SFBRO373EDL 3.73 Ratio, UD60SFBRO410EDL 4.10 Ratio, UD60SFBRO456EDL 4.56 Ratio, UD60SFBRO488EDL 4.88 Ratio, UD60SFBRO538EDL 5.38 Ratio
Dana Eaton Air Locker part Numbers: UD60SFBRO456AIR 4.56 Ratio, UD60SFBRO488AIR 4.88 Ratio, UD60SFBRO538AIR 5.38 Ratio
Shop all Drivetrain by Dana/Spicer here. Have questions regarding compatibility or requirements? Contact our team at the email or phone number below.
Contact Us
Follow Us
mpeugeot
No 4.27 love... jeez.
JoeOffRoad
Joe
Medford, OR
tomsoffroad.com
1969 Ford Bronco
One thing to note with the Ultimate 60, your wheels/tires and brakes will fit the ultimate but you will need to replace the rear driveline.
Yeti-X
Todd
Eau Claire WI
2022 Bronco Badlands 4dr
My question is the dana 60 going to be available in custom widths to match the pre runner long travel fronts
JoeOffRoad
Joe
Medford, OR
tomsoffroad.com
1969 Ford Bronco
There will be 2 additional widths coming from Dana in a 73" & 76". We do have them available to pre-order with an estimated shipping ETA of 5/15. It is possible that it will take longer than that.
Demon4x4
Randall
Houston
demon4x4.com
2024 Bronco
Will a 4.7 gear ratio become available for the rear 60?
Any thoughts on a full float version? Or is there not enough room between the six lugs?
tomsoffroad76
tomsoffroad76
TOMS
Medford, Oregon
2022 Ford Bronco
We have some suspicions regarding not offering a 4.70 ratio, while it is stock, most every users upgrades tire size when moving to a 60 and this needs to move to a shorter gear. The uptake on the SKU probably doesn't warrant offering it.
We'll have to reach out to Dana and discuss design specifics. It's technically feasible as Jeep just offered the full-floating option on some models recently, which are Dana products as well.
Stay tuned!
Valhalla
Valhalla
Cleveland Tn
2023 Bronco,1996 Bronco, F350, JKU, MKZ, Silverado
Do you guys foresee a beefed up 44 in the future that is wider for the rear? I will most likely go to a 6" wider 60 so mostly just curious.
tomsoffroad76
tomsoffroad76
TOMS
Medford, Oregon
2022 Ford Bronco
Honestly, if the market demands it, we would just build our own. We already do a ton already for the early Bronco.
