Slick85
Richard
Austin, TX
After having the Big Bend with base stereo for a bit I finally went ahead and did a complete stereo overhaul. Went to see the guys over at Audiomaster in Austin and they knocked it out of the park.
The components are:
  • Audio Dynamics Point Source PS 343 tweeter/midrange combo in dash
  • Audiofrog GB 60 6.5" midwoofer in custom kick panels
  • Audiofrog GS 42 coaxials in rear pods
  • Audiomobile Encore 12" subwoofer in custom box
  • Helix V Eight DSP amplifier with Helix Conductor controller (base knob, etc.)
  • Soundigital 800 watt amplifier for subwoofer
  • Soundskins sound deadening
I asked them to make everything as stealth as possible which they did and with minimal modifications to the vehicle which they did. I honestly couldn't be happier with the result! I added some pics below for everyone.
Ford Bronco Complete Stereo Overhaul (Upgrade From Base Stereo)! front (2)
Custom kick panels
Ford Bronco Complete Stereo Overhaul (Upgrade From Base Stereo)! kicks
Sub box with extra storage pocket on side without woofer
Ford Bronco Complete Stereo Overhaul (Upgrade From Base Stereo)! subfar
Amps
Ford Bronco Complete Stereo Overhaul (Upgrade From Base Stereo)! amps (2)
Amp cover with grille for airflow
Ford Bronco Complete Stereo Overhaul (Upgrade From Base Stereo)! ampcover
Close up of sub box port
Ford Bronco Complete Stereo Overhaul (Upgrade From Base Stereo)! subclose
Below are stock images of the subwoofer and the front speakers in the dash
Ford Bronco Complete Stereo Overhaul (Upgrade From Base Stereo)! encor
Ford Bronco Complete Stereo Overhaul (Upgrade From Base Stereo)! ADPS343-Front-Profile-No-Grill
The knob is a Helix Conductor controller which acts like a base knob and can also fade out the rear speakers
Ford Bronco Complete Stereo Overhaul (Upgrade From Base Stereo)! conductor
ChrisB351
Shreveport, LA
If it sounds as good as it looks itll be awesome. Just curious to why the kick panel plate and not just mount behind the stock piece?
Rick U
Very nice. Does the helix amp have built in dsp?
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
The components are:
Custom kick panels
Amps
Very nice@
Slick85
Slick85
Richard
Austin, TX
Because the midwoofer is very deep plus the stock plastic is flimsy.
Yes it does!
Bruno
Bruno
Sierras
MASSIVE AMOUNT OF SPACE DEDICATED TO A SUB.
What about 2x smaller subs stashed under some seats or something...
or cut a hole in the back and install a metal box from under the vehicle.
or listen to Yacht Rock....
Ford Bronco Complete Stereo Overhaul (Upgrade From Base Stereo)! 51410_full
BRKOBILLY2
William
Long Island, NY
Ford Explorer
I have heard that Audiofrog is highend. I tested on Crutchfield and sounded great. Nice job, but you must really like your music!
  • Like
Reactions: Cat
JP Fabrication
LA, CA
Bronco, VW R32, OBS Chevy Crewcab
Very nice. When I saw Audiofrog, I knew this was going to be good. then it only got better, Helix with Conductor:)
Slick85
Slick85
Richard
Austin, TX
Because if you do that then the seats can't fold down... plus I've heard some 6" subs under seats and they get decently loud but just don't hit that deep, the other side of the box without the sub has storage space that is hidden too.
Ya it was started by a former sound engineer for JBL, the midwoofers are ridiculous it sounds like a drum set is in my truck :ROFLMAO: :ROFLMAO: :ROFLMAO:
22OBX
Bryan
Hartford, AL
Nice work! Install Looks familiar to my build I posted months ago, hmm?
I have two tens and rear filler floor has storage underneath and is actually a great place to hide anything you do not want seen. I can remove it, pivot it up to access tools if needed.
Ford Bronco Complete Stereo Overhaul (Upgrade From Base Stereo)! 94C8E67B-35EC-4220-8EB4-121A85A73579
Ford Bronco Complete Stereo Overhaul (Upgrade From Base Stereo)! E78239CC-443B-4A00-803F-93AC98FED500
Bruno
Bruno
Sierras
why not build the sub into the lower storage box
Ford Bronco Complete Stereo Overhaul (Upgrade From Base Stereo)! 71BXZd36ZvL._AC_SX679_
buzpro
Binky
Tacoma
The components are:
Custom kick panels
Amps
Total out the door cost?
