- Caleb
- May 3, 2022
- 233
- 1,007
- 843
- St Louis MO
- 2021 Bronco
- Outer Banks
Direct fit for 2021+ Ford Bronco 2.3L and 2.7L EcoBoost
Boost your Ford Bronco's performance with the Mishimoto Intercooler! In this video, we give you an overview of the Mishimoto Intercooler for the Ford Bronco. We will talk about the benefits and the advantages of running an intercooler on your ecoboost powered Bronco. Stay tuned for the Step by step installation so you are informed and ready to install this Intercooler on your Bronco!
- Dyno-proven max gains of 5.7 whp and 5.3 lb-ft torque (2.3L EcoBoost) / 6.5 whp and 6.5 lb-ft torque (2.7L EcoBoost)
- 21.2°F (2.3L EcoBoost) / 15.8°F (2.7L EcoBoost) reduction in outlet temperature over stock intercooler
- 7% less restrictive than stock intercooler
- 77% increase in core volume
- 175% increase in fin surface area
- 4.7-inch thick intercooler design for maximum flow and heat soak resistance
- Optimal core design for maximum cooling efficiency with minimal pressure drop
- All-aluminum, TIG-welded construction
- Durable bar-and-plate core for superior durability and performance
- Cast aluminum end tanks are precision TIG welded to the core for increased pressure tolerance and reliability
- CNC-machined 6061 aluminum inlet and outlet flanges
- Does not interfere with adaptive cruise control or 360° cameras
- Available in stealth black or sleek silver powdercoat
- Mishimoto Lifetime Warranty
