Ground_zero298
Scs michigan
Easy upgrade for those that like to see what’s going on under the bronco.
Why you ask? I like to see in real time my under lines, wheel angle, suspension load/angle, split high spots, which tire is slipping/lifted and anything falling off the truck or dragging.
Looked at a lot of kits. Settled on this wireless one. Screen and camera quality are really good. It comes with 2 cameras and is capable of supporting 4. Can we say rear trailer view?
Also supports a memory card for full hd recording. Has all the mirror flip options, supports split view.
Unit
https://www.amazon.com/gp/aw/d/B07FM3YLT5?psc=1&ref=ppx_pop_mob_b_asin_title
$199.99
Additional cams
https://www.amazon.com/gp/aw/d/B096ZB181Z?psc=1&ref=ppx_pop_mob_b_asin_title
$99.99
Hook up is straight forward. They have 2 wires. Pos and neg. That’s it. Camera stream connection is wireless and damn near instant. Refresh rate is great, no blur. They have sufficient ir lights to see everything underneath at night.
I first mounted the screen above my lifter switched. Unit fits perfect in that spot. I just used 4 short screws to mount it
Ford Bronco Belly / underbody cam installed 🎥 62F20841-B3DE-476A-B233-571B7B48FD71
Ford Bronco Belly / underbody cam installed 🎥 8F71414F-A318-4AEA-85E8-416BFAB03D86
Ford Bronco Belly / underbody cam installed 🎥 92B21E5F-B6BA-48A7-90F7-78B4D0583462
Then I tested and picked out 2 semi protected spots for the belly cams. Higher than the skids but can still see the wheels. I did hit 2 known spots at holly for dragging the belly. Cameras never hit, but did drag the mid skid and tank skid.
Ford Bronco Belly / underbody cam installed 🎥 32011E6C-A068-4707-A887-80A061EE9BE0
Ford Bronco Belly / underbody cam installed 🎥 82FF1CC9-8CDB-4503-A3CA-3FB104A6F3F4
Ford Bronco Belly / underbody cam installed 🎥 16EF9E1E-ED1F-403A-843C-CB6B7DEDD44A
Ford Bronco Belly / underbody cam installed 🎥 97AB88FB-20F1-4790-8871-AD456DDBA217
I mounted the brackets with a single self taper. That way the screw head should snap off before the camera get damaged. I used a 5/32 bit to pre drill the cross bars. Front bar you have to stay in the bottom 1” where my finger is. Above that, it’s doubled. Metal is thick but soft.
Ford Bronco Belly / underbody cam installed 🎥 F3D1794A-AA6D-4E81-B4F1-86CA5821E64B
Ford Bronco Belly / underbody cam installed 🎥 9F754BC9-BEFB-4C30-8A93-F8DE73EE22A6
Ford Bronco Belly / underbody cam installed 🎥 2D7A9810-B88F-4C45-B6F5-17B6CD9B0F66
Ford Bronco Belly / underbody cam installed 🎥 6785A4B5-8050-4EA3-A86A-3C9944EADE09
Rear cam facing forward is the same 5/32 pre drill with 1 self taper. This metal is a lot thinner. No restriction for hole location on this one.
Ford Bronco Belly / underbody cam installed 🎥 8271FFE3-0556-474D-ADB7-525598495205
Ford Bronco Belly / underbody cam installed 🎥 C97113DB-70EB-4DBE-83C5-6D1FEEA848CB
I ran the wires through the frame on the drivers side then into the engine bay and hooked the cameras into my grill and visor backlights on a lifter.
This setup performed above my initial expectations for quality, blurring, and not getting hit. If you wheel alone like I do most the time, this is a very worthwhile upgrade. Specially adding in 2 more cameras for trailers. Can do a inside and rear. Leave them attached. When you hook up to the trailer, they will auto connect.
Ford Bronco Belly / underbody cam installed 🎥 19B081D4-E710-45A0-9F6B-B3483C088FFE
Ford Bronco Belly / underbody cam installed 🎥 1FDB8B17-CDCB-4119-BF02-AC354413486C
Ford Bronco Belly / underbody cam installed 🎥 E4F0B420-647B-45C7-BBEE-B9564A46DBBF
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Interesting setup. I can see how this could be helpful for sure.
Dumb question, but won't that become useless really quickly once it's dirty? It won't take long whether it's dust or mud.
Edit: I wonder if you could attach and run a windshield washer line to that camera - Similar to the front camera?
Ground_zero298
Ground_zero298
Scs michigan
I was worried about that also. My back up plan for that is to run the rear wiper line down under and mount a spray head by each. Seeing I’ll never use my rear wiper.
After a day out, I only had a real thin layer on the rear facing forward. Front one was still shiny, at least the lens was. Pics of the screen, though look like crap from taking them with my phone, we’re taken without cleaning the cam lenses. No mud splashed on them.
Going to put some cerama coat on them today. Down pipes first though.
Aztec1382
Sam
F350
Cool
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
Unit
$199.99
Additional cams
$99.99
That's awesome!
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
how waterproof is IP69 for the cameras?
would love to know how it fares after a few water-fordings!
Ground_zero298
Ground_zero298
Scs michigan
Ground_zero298
Ground_zero298
Scs michigan
Put the third camera in a 5 gallon bucket of ware. Will let it sit in there for today. Was transmitting.
Ford Bronco Belly / underbody cam installed 🎥 58D8C329-7653-472D-95B5-1BE19476E887
Ford Bronco Belly / underbody cam installed 🎥 ACB97C6D-C682-4596-A060-E4FB8038EF22
Big Rig
2001 Silverado 1500
Unit
$199.99
Additional cams
$99.99
This is a really creative idea! Nicely done.
adrewpower
Drew
Bronco 2dr & BRrrrRaptor
Have you timed the delay? Curious how long it is. I thought about mounting a GoPro to the front since a BD couldn’t be upgraded to have a front facing camera. But the GoPro delay is about 3-5 seconds. Obviously not ideal. Curious to know if this has a shorter delay.
Ground_zero298
Ground_zero298
Scs michigan
If you need to run power to the camera then is there a big advantage of a wireless transmitter?
Instal wise, Yes. No physical wires from the cameras to the screen. Just from the cameras to a 12v source. Quality wise, hard wired is always the best option. I have not had one of these cameras not display full signal yet.
Ground_zero298
Ground_zero298
Scs michigan
Maybe a 1/10 of a second. Can’t even notice it when turning the front wheels.
Ground_zero298
Ground_zero298
Scs michigan
3 1/2 hours in the bucket. Still transmitting.
Ford Bronco Belly / underbody cam installed 🎥 10CDC0F8-918A-4990-85D7-02D72A599D42
Ford Bronco Belly / underbody cam installed 🎥 A8CA5922-9F10-4478-9044-B5EFB1BB5DE6
Bad_Bronco
Peter
Port Coquitlam, BC
1963 Chevy Nova SS, 2021 Ford Bronco WildTrak
Very nice job as always...... If I go this way, I will look at making a bracket for the cameras. I will see what I come up with and let you know.
