Jimmyleetennessee
Jimmy
Bluff City
2015 ford f150 fx4 2.7
There is a lot of misinformation on here regarding these two gear ratios, so I wanted to put it bed once and for all:
Overview:
The 4.7 ratio comes standard with the sasquatch package, and cannot be added independently without the entire sasquatch package.
THE DELIMMA:
I'll start with saying that my badlands doesn't have the sasquatch package. This should mean that my bronco will have a lower crawl ratio than a sas, since it has higher gearing. It should get better gas mileage, even run lower RPM's on the highway. It should even be slower on take off, right! Wrong!
The Explanation:
When we change the tire size of our vehicle, we also change the mechanical advantage. Think of a winch: the more line on the drum, the weaker the pulling power of the motor. In other words, the larger the circumference of the drum, the more strain on the winch motor. In a nutshell, added layers of cable=less mechanical advantage.
This same logic applies to the Bronco. A 4.7 ratio with 33 inch tires would indeed have better mechanical advantage than a 4.46 ratio! However, adding 2 inch taller tires (sasquatch) will decrease the mechanical advantage, therefore nearly equalizing the crawl ratio to a 4.46! My guess is, Ford realized this while developing the bronco; hence the 4.7 ratio option...
To Summarize:
A 4.46 ratio with 33 inch tires will have an equivalent mechanical advantage to the 35 inch with the 4.7 ratio on the sasquatch. That being said, if you are planning to change for bigger tires, you will lose SOME of your mechanical advantage. Therefore, if your plan is to put larger than 33 inch tires on your bronco (I didn't want bigger), then you definitely need to go with the sasquatch package to maintain as much torque as possible with the added rotational forces.
Cheers!
**As pointed out by some replies, you CAN get a manual badlands with the 4.7 ratio, but you do lose trail-turn assist.. which is why I didn't. I was strictly speaking of the automatic, I should have clarified.. although that is not at all the point of my post**
Karl_in_Chicago
Karl
Chicago
Your Badlands *came* with a 4.7 ratio as standard, Sasquatch or not. It was the optioning of the automatic transmission - either intentionally with the standard 2.3L motor or by choosing the 2.7L motor with required auto - that changed the ratio to 4.46. To say that one can not have the 4.7 without optioning Sasquatch is not correct (and this bronco has been beaten to death, repeatedly, on numerous other threads here).
GToddC5
Todd
South Jersey
www.bronco6g.com
Literally not the facts. Again. Ugh.
AMTRV
Oliver
United States of America
22 Badlands 4dr, 22 6.7L Tremor, 1940 Ford Cpe
My 22 2.7l Badlands non Sas came with the 4.46 axle ratio......as did all non Sas Badlands with the 2.7l. There is no option with the 2.7l short of Sas Pkg.
Morganstein
2021 Ford Bronco Badlands
My Bronco is a 2021 Badlands with 4.7's and no Sasquatch. 2.3/manual.
mpeugeot
It's only a 5% difference in gearing, I could run 35's on my Outer Banks and probably not feel enough of a difference off-road to care (and that's with the 4.27 gears), and the difference on road wouldn't be a big deal as the 2.7 has more than enough low end grunt. I currently run 33.5" tires (actual - not 34.5" sasquatch package tires that pretend to be 35's).
You don't "need" the Sasquatch package or 4.70 gears for 35's.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
The math checks out.
However IMHO, with these deep overdrives, we're all a bit undergeared. I wish I had 5.13s with 35s. 4.70 with the 33s felt pretty good but even 4.88 would have been nice.
Jimmyleetennessee
Jimmyleetennessee
Jimmy
Bluff City
Correct, you do not need it. Though that 5 percent is lost by the increase in size of the bigger tires. The rotational force is increased by the larger circumference.
swooshdave
Portland, Oregon
Mustang
People who measure tires by the half Inch have serious issues.
mpeugeot
swooshdave
Portland, Oregon
Mustang
Hey, I also live my life a 1/4" at a time... LOL
Didn't have to guess at that. Also our sympathy to your significant other. :p
Anyways, apparently some people need to see the long math on this. Which is also sad.
Nice job explaining it, @Jimmyleetennesee
Bigmoose
Jon
RI
2019 Flex Ecoboost Limited
I have a BD with 4.46 gears and also run SAS tires and suspension. Truck drives great and I have no issues with power. Averaging 20mpg.
For reference my previous fun car was a 2004 terminator running 20psi on E85 making close to 700whp.
