lethaljake
Jake
West Palm Beach, FL
2022 F-150 RCSB 5.0
Hey all!
Eibach just released their Pro Lift Kit for the 2021+ Ford Bronco’s equipped with Bilstein PSD Shocks (Sasquatch Package)!​
These not only raise the truck 2.3" in the front and 1.6" in the rear, but also provides a balanced ride quality, control, and improved off-road capability.
By optimizing height and rate within the limit of each shock, you retain factory ride characteristics and a lift ready to tackle the toughest terrain, as well as more comfortably support a larger wheel and tire combo!
Manufactured using championship winning race spring technology
  • Finished in Heavy-duty corrosion resistant silver coating
  • Limited Lifetime Warranty
  • Made by Eibach in the USA
If you’re looking for more lift and suspension, check out Eibach’s Pro Truck Coilover’s for the Bronco’s as well!
These are fully-adjustable performance coil-overs that provide up to 4" of lift and the perfect balance of off-road performance and control.
We currently run these on our First Edition Sasquatch and couldn’t be happier with the ride!
  • Pre-assembled for direct bolt-on installation
  • Utilizes our ERO Championship proven Off-Road racing springs
  • Designed to work with factory control arms for an increase in height without accelerated wear to ball joints and bushings
  • Developed specifically to provide a balanced ride quality on and off-road
Of course, feel free to reach out to any of us here at Lethal Performance if you have any questions!
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
Hey all!
Those look great!
Sumo
Sam
Georgia
Subaru wrx sti
Impressed with eibach springs in the past, I would buy these, when/if I get my23 build.
BigGarnet
‘21 Bronco
This is what I have been looking for. I like the Bilstiens that came with Sasquatch, and much prefer this to a spacer lift. Is there a B6G launch discount for the Pro Lift?
Frankie945
Frank
Louisville KY
Q50
Use promo code stangmode for 10% off it came to $377 shipped. Just ordered a set to try out.
deltapine1
Terlingua
1996 FZJ 80 Landcruiser
I have these installed on my 2 door hartop. The ride is much nicer than the stock Bilsteins. Ended up with a lot more than 1.6" in the rear. The front end drops quite a bit on panic stops compared to stock Bilsteins. I am corresponding with Eibach's Customer Service and providing them with measurements now. They have been very prompt and proactive responding to my questions. I like the fact they are made in the USA and so far have had great customer service. They are very good quality in appearance but I ended up with a lot more lift than I wanted.
Altitude
Howard
Papillion, NE
2015 Grand Cherokee, 2008 Suzuki B-King
Hmm, only for Sasquatch and not the Bilstein's that come standard with the Badlands? Agreed, I'd much rather do a spring swap than deal with pre-load or top hat spacers for a budget lift.
Frankie945
Frank
Louisville KY
Q50
Nobody cares about diff drop brackets on this forum. It’s all about curb clearance at the mall.
It’s 2 inches of lift and stays with in the factory suspension geometry. Why would we want a diff drop for this.
Mikerider
Washington
Raptor, Ranger, Mustang, Focus, Explorer
I loved the ride and stance of my Eibach spring kit for my 2013 raptor but it ate through CV boots at the higher angle. hesitant to try that on the bronco.
Frankie945
Frank
Louisville KY
Q50
If advertised correctly this lifts you less than a 2.5 perch collar lift I don’t think it’s going to eat up boots. I think we’ve found out by now that the perch collar lift is best way to add lift without over extending the cvs or tie rod angles.
After I receive mine I’ll let you know how it rides on my mall adventures.
