Bronc4x4
Schwinn
If it were mine, I would not try to correct the brown spots myself. Let the dealer do it.
I wouldn't trust the dealer with this. I'd attempt (as others here suggested) chemical decontamination/iron remover followed by clay bar on an out-of-sight spot (after watching some pros do it on YouTube). Don't forget to apply some paint protection over the places you used the iron remover.
If you're not comfortable with 'prosumer' detailing, find a higher end detailer with good reviews and references.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Love the Bronco and glad it's treating you well!
Not sure if anyone else mentioned this, but there's a product from Autoglym called "Magma" - It removes brake dust and iron, which can cause specs like you described. It almost looks like rust. A buddy of mine uses this on his black vehicle and swears by it - You can find it at Canadian Tire. Might be worth a shot, as that'd be a simple, easy fix if that was the issue.
Thomas1984
Thomas1984
Thomas
St.johns Newfoundland Canada
Dodge Viper
Beautiful tire rim set up. Just a quick question though, did you get the Sasquatch package and then change them out? Or did you get the standard 33‘s and switch them out? I can’t tell from the lift versus your tires. Beautiful scenic pictures as well. I love you you’re taking your bronco.
Came with standard 33’s, it’s the standard badlands. No rubbing with 35’s
Bronco cat
Carl
Morgantown wv
‘20 Explorer ST, ‘19 GT350, ‘21 Bronco Sport
Some are white spots others are white forming into brown spots
If it’s on the hood it’s cortisone. Aluminum “rust” turns an opaque white color. Ford has a history of issues with aluminum panel finish. In this case I would almost bet there was steel contamination prior to painting the hood. That would account for what is going on.
AMK610
Andy
PA
2019 RAM 1500 Rebel
100% agreed. I’d never trust a dealership to detail my car either. I’d bet they don’t even know what rail dust is and would end up submitting a warranty claim to ford, when all of this could be fixed for about $15 and a few minutes of OP’s time lol
wetdog
Bruno
pacific coast
2019 jl
Not sure if its the same thing but our 19 wrangler has bubbling paint around the hinges door are aluminum ,its a common problem.
ohvrider
San Jose, CA
2019 Ford F-150 Raptor
I've heard of other cars needing the battery trick to fix electronics too. I guess its like Ctrl-Alt-Del on a PC (or power cycling if that doesn't work).
The bronco's are mostly steel, I think only doors, hood have aluminum?
Its the F150's that are all Aluminum.
goatman
Richard
Bakersfield
'22 Badlands 2 dr 2.3L, 2000 Ford F450 PU, 2001 Jeep Cherokee
Had my bronco over a month and I am enjoying every minute, well built, nice to drive compared to a jeep, lots of power from the v6, plenty of room, electronics work well only thing I had happen was the 12” screen stopped working I gad to disconnect the negative battery terminal, it never happened since, I reported it to the dealer, another thing is spots forming on my hood and fenders that looks like rust, I just got back from the dealer they took pictures to be sent off for a decision. It’s ridiculous why is a vehicle rusting already? I thought these broncos we’re made from aluminum. I attached some pictures. Other than that it’s been a blast!
Don't know if this has been answered yet or not, have not read this whole thread. The rust spots are what we called environmental fallout. It is minor rust particles from shipping on the train, etc. The dealership detail department knows what to do about it. Really, should have been handled before you took delivery. Just throwing this out there, if you don't already have more info.
The REAL Zemaniak
PaddyO
MTL
JK2D
Noticed your photos with top off: assuming you’re not using the soft top
Was wondering how much of a hassle, if any, is taking off and putting back on the hard top? And Can this be done by 1 person ?
Thomas1984
Thomas1984
Thomas
Dodge Viper
I can remove the 3 front panels myself and remove the bolts for the back cap, but removing the rear cap requires two people, not heavy but awkward to lift, I did it once but I won’t risk it again because it’s tricky, so two people is required to not risk breaking something.
skater777
Massachusetts
Ford Escape
Thanks for the photos. The black looks great on the Badlands with the MIC roof. Perfect blend of black and gray. It wasn't necessary for you to tell us how much you like the Bronco, as you have already driven more miles in a month than I have driven all year! Enjoy!
lasttj
Robert
'06 Jeep TJ, '16 Ford F150, '65 VW Beetle
But if the damage was caused while the vehicle was being transported, the correction should be covered by the warranty. If he tries to correct it himself and does more damage, he's screwed. Just my two cents.
Mcfly
LR4
Those wheels are bad ass - best pics I’ve seen so far for wheel upgrades - I’d swap out for those in a heartbeat.
ssolypop
Solomon
Hawaii
Avenger
Was your BL stock or Sas? Did you add lift or plan to?
MOrunning04
Dan
Johnston, IA
Ford F-150
I had tiny little spots on my white F150 and it was brake dust. Hopefully that’s all it is.
