redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Haven’t seen this mentioned yet. Bestop posted a teaser of their new fender flares. Looks like they square out the standard round fenders/quarter and are meant to mimic the ‘66 accessory. From close they still have the round edge underneath - but, have the potential of a nice appearance. Looking forward to more photos and angles.
First look video:
Here are a few screen shots.
Ford Bronco Bestop Fender Flares For Bronco - First Look Video 395f8ccc-92d3-4bbc-9355-1a4596023e2c-png
Ford Bronco Bestop Fender Flares For Bronco - First Look Video 7dca8935-48c4-482b-a262-ceceac886d49-png
redone17
redone17
Cold Spring, NY
As an old millennial (I missed gen x by three-ish weeks), any way to view that is not these new-fangled social medias?
That’s the only thing they’ve posted thus far. “More info coming”
Ford Bronco Bestop Fender Flares For Bronco - First Look Video 395F8CCC-92D3-4BBC-9355-1A4596023E2C
Ford Bronco Bestop Fender Flares For Bronco - First Look Video 7DCA8935-48C4-482B-A262-CECEAC886D49
Beach_Bum
Ken
St. Augustine, FL
2023 Outerbanks Bronco
She has a Badlands with the stock OEM wheels (+55 offset). Note the poke with the stock wheel. These look to offer some style over the typical flare deletes. If someone kept the underside black where the clumsy round/square transition is made and painted the upper side body color, it may not look that bad. These certainly look better than the other aftermarket flare that attempted the square flare over a round hole recently.
Ford Bronco Bestop Fender Flares For Bronco - First Look Video 1664019330390
redone17
redone17
Cold Spring, NY
I’m far from convinced myself - but, nice to see other options. I’m really just interested in something strong, durable, easy to clean and around $100 a corner.
The stock flares leave a lot to be desired. I just don’t think anyone has come up with a solid solution yet.
Just figured I’d share.
Ground_zero298
Scs michigan
Nothing against you or the post. It’s the styling, the shape, the hard corners, and the rounded underneath. Matches none of the lines. But will give some other makers ideas. Someone will get retro lips made that match eventually. If cheap enough they would make good temp trail runners like you said.
Jeverall
James
Tampa fl
Jeep Grand Cherokee
I dig it , could look better if painted to match body …. Also need a couple more inches away from body to cover my 20x10 -18 offset poke 😆 need more pics
mattymik
Matt
Houston, TX
2019 Honda Odyssey, 2023 WildTrak
Am I a fool for wondering why the flare sits so high?
I would think the flat top could sit lower, covering the visual curve of the wheel well, and would still allow for tire clearance. Then you wouldn’t have that awkward curved interior and squared exterior portion? And the interference with the fuel door?
Ford Bronco Bestop Fender Flares For Bronco - First Look Video D44A06C7-552F-4A5A-9844-D1AE72EDD6C1
cdoublev
Charlie
Massachusetts
Mini Countryman
I for one am digging this. Good to know those that don’t want to splurge on Heritage trims can eventually get the squared off look
redone17
redone17
Cold Spring, NY
I was thinking the same. Why even show the rounded well underneath?
Beach_Bum
Ken
St. Augustine, FL
The just responded to my comment that they can be removed just not as easily like the OEM flares. Looks like these will serve as a stylized flare delete providing slightly more coverage than just a flare delete. But also not providing flare coverage that the stock OEM flares provide. Those with Sasquatch will have much more of the tire exposed.
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
First look video:
Those look good!
