604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Looks great! The true test is after a year of baking in the sun and extreme Winter weather (I realize you're listed as Texas, so less of an issue).
Hopefully it holds up, because it looks awesome!
ByrdDogX
Olive Branch, MS
22 Ford Bronco
Looks great. Only concern I would have is scratching if you plan to remove panels or top. My hard top Jeep was a PIA to keep from scratching.
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Looks great! Let’s go MY23 for the factory option!
SCBronco1
Peter
2019 F150 Lariat Fx4, 2012 BMW X3, 2011 Escape
mikeeshim
Los Angeles, CA
MBZ E350, supposed daily driver
Wow, that looks so good. Perhaps I need to think about that once I get my TRMR roof rack installed since the top ain't coming off after that!
DT BB
Darin
Chicagoland
f150
True.....I am super carefull with my hardtop and still have a few bumps and bruises! :)
jaruss01
NJ
The mid panel on the 4 door would be almost impossible to remove with one person and no scratches on a painted top. You need to shimmy it a bit over the clamshell. With a mic top the “scratches” rub off easily with a wet thumb…but would surely add light scratches on a painted top.
So say goodbye to removing the mid panel with a painted top unless you have help.
StogieDave
Millstone Township, NJ
2023 Wildtrak, 2005 Toyota Sequoia
I wonder how raptor lining the top would work, should be more durable then paint
SweetFoot
SC
2022 Bronco
LOOKS AMAZING!
