Aman
Aman
Northern NJ
I finally got around to installing the KR Air Coupler Switch Bracket and ARB Pressure Control Kit. I went overboard ordering hoses and couplers from @4x4TruckLEDs.com, but in the end only needed what is listed below to achieve a clean install.
Parts List:
ARB On-Board Twin Air Compressor
KR Off-Road ARB Compressor Engine Bay Mount
KR Off-Road ARB Compressor & Air Coupler Switch Bracket
ARB Air Hose Coupler (JIC-04 37 Degree Flare Fitting)
ARB Air Hose Coupler Dust Cap
ARB Reinforced Hose JIC-04 0.5m
ARB Reinforced Hose JIC-04 0.3m
ARB Adapter 1/8 BSP (M) JIC-04 (M), 2 Pack
ARB Adapter 1/4 NPT(M) JIC-04(M), 2 Pack - Only 1 required
ARB Air Line Adapter Fitting 45 Elbow, 2 Pack - Only 1 required
Please note, due to the configuration of the ports on the ARB regulator I was unable to have the input and output hoses on the same side, so the layout is a bit more spread out than I would have preferred. Also, the spot where I mounted the regulator needed to be twisted a bit so the pressure sensor would clear the coupler. Finally, the screw I used for the regulator mount was a bit too long, so I used four washers to take up the extra space.
Initially I planned on using the supplied ARB switch, but I decided to forgo that idea because using the upfitter switches made for a cleaner install.
Ford Bronco ARB Twin Air Compressor and Pressure Control Kit Install D478BBB7-7D1E-44AE-B04A-6287ECC340CE
Ford Bronco ARB Twin Air Compressor and Pressure Control Kit Install AAD3C60B-F39E-4971-B661-224AFD1438BB
Ford Bronco ARB Twin Air Compressor and Pressure Control Kit Install 4CEA8A36-0237-4AC0-822E-352D022A6E6E
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
You basically ordered every single ARB fitting/hose they made, lol. Glad to see the end result
Ground_zero298
Scs michigan
You plan on refunding me my money for the return I sent back 3 weeks ago?
4x4TruckLEDs.com
Adam
Lindenhurst, NY
I don't know what return you're talking about. If you have an order specific question the best way to get answers is to email us, message us here, call us or text us
Aman
Aman
Aman
Northern NJ
Haha, yeah figured I was going to be stuck with a bunch of extra parts, but would have hated to keep buying one-offs. Having everything on hand made it easy to test a number of different configurations and settle on the best one.
Thanks for getting everything to me so quickly!
4x4TruckLEDs.com
Adam
Lindenhurst, NY
That's what I do. If i'm doing a project I just order a few of everything. Just ask my guys about the fishing rod holder nuts/bolts :)
I ordered about $1500 worth of nuts/bolts to figure out exactly what I needed for the fishing rod holders. BUT now we have 2 nuts/bolts bins with all types of sizes. Great to have on hand.
JediMcMuffin
Tommy
2021 Bronco Badlands
That's pretty darn cool. A splurge for sure, but time is money right.
Interior guy
Dan
2022 bronco
So with all you had installed what does that run approximately?
JeebusCripes
Mn
‘94 M998, ‘89 Wrangler
I hear they will even respond to smoke signal or carrier pigeon. Point is they are here for you!!!
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Indeed. But this person hasn't actually reached out to us... so we're not sure who they are or what return they are speaking about.
Aman
Aman
Aman
Northern NJ
Bluetooth control for your ARB compressor.
Still have to connect a hose, but if you have a MORRFlate type system, you hook it up, set the PSI via your phone, and walk away.
ARB Compressor Connect
Ford Bronco ARB Twin Air Compressor and Pressure Control Kit Install 545605C2-C459-4D4F-A905-7742A66BA2E1
Ford Bronco ARB Twin Air Compressor and Pressure Control Kit Install 11974B28-3939-4029-912B-DF6109CD96E9
iamchewby
Chewby
Which switch did you wire it to?
Aman
Aman
Aman
Northern NJ
Aman
Aman
Aman
Northern NJ
I connected both the air compressor's trigger wire and the pressure kit's power lead to switch 6. More than enough amperage to handle both.
