Ryan at ARB
Ryan
Auburn, HI
arbusa.com
Jeep LJ, Ford Ranger, Ford Bronco
One might argue that Under Vehicle Protection is the most important accessory for off-roading. Unlike bumpers and rock sliders, a solid under vehicle protection system/skid plates will ensure the vital components of your drivetrain remain intact.
Ford Bronco Armor for your Bronco: ARB’s Under Vehicle Protection System / Skid Plates Untitled-3
ARB has developed a frame-mounted system that protects your Broncos steering, engine sump, transmission, transfer case, and much more. The press-formed and folded 3mm sheet steel skid plates come in at 88lbs installed and will give you the peace of mind you need on the trail.
Front Panel: Engine
Differential/Sump Panel: Front differential and mounts, rear of engine sump, and power steering
Transmission Panel: Stabilizer bar and transmission
Transfer Case Panel: Transfer case
Ford Bronco Armor for your Bronco: ARB’s Under Vehicle Protection System / Skid Plates exploded 2
Ford Bronco Armor for your Bronco: ARB’s Under Vehicle Protection System / Skid Plates exploded 1
For us to retain the strength of our full under vehicle protection system when off-road, vehicle servicing requires the removal and refit of the panels to obtain access to drain plugs and other service points. Removing each of the plates also provides you with the opportunity to check for damage and remove any foreign matter, dirt, or debris.
ARB’s UVP will fit with any ARB front bumper and OE front bumper. Fitment has not been confirmed with other bumper designs.
Additional Features
  • Laser cut 3mm sheet steel
  • Zinc plates and powder coated in a silver texture finish
  • Recessed mounting bolts are protected and easy to remove for vehicle servicing
Additional Notes:
  • This ARB UVP set does not fit the Bronco Sport.
  • The ARB’s UVP will fit with or without an ARB front bumper. Fitment compatibility has not been confirmed with other bumper designs.
  • To retain the strength and protection required of an ARB UVP, full vehicle servicing will require the removal and refit of panels to obtain access to drain plugs and other service points. Provision is provided to drain engine oil only with a removable insert in the second pan
Part # 5480100
Ford Bronco Armor for your Bronco: ARB’s Under Vehicle Protection System / Skid Plates UVP Anderson Composites
View attachment 5480100 Bronco UVP Instructions 37801053.pdf
TahoeTexan
Tod
Reno, NV
2022 Bronco OBX
$699 for full protection? 😳
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
Wow. If that’s $700 for full protection on a 4 door, I am in shock. I got the Metal Cloak and there were substantially more.
darkscion0
Canada
2021 Badlands Sasquatch
It's an amazing system. I just installed it. Happy to answer any questions anyone has on it or assist with any difficulties anyone has installing it. There's some spots on the instructions that aren't great.
Rick Astley
Up Doug's ass
d
Front Panel: Engine
Additional Features
Additional Notes:
Part # 5480100
Damn that thing is beautiful!
Ryan comes in again with a haymaker!!!
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Failure to have a fuel tank skid makes the set incomplete. I think you have improved on the factory set in a few area but overall money is better spent on factory skids because a fuel tank skid is a must have item.
For how long this product has been available there hasn't been any reviews or photos. I am disappointed in this thread as the pictures are still crap.
darkscion0
Canada
Let me know if there's something specific you want to see.
Ford Bronco Armor for your Bronco: ARB’s Under Vehicle Protection System / Skid Plates 20220623_172821
Ford Bronco Armor for your Bronco: ARB’s Under Vehicle Protection System / Skid Plates 20220623_192526
Ford Bronco Armor for your Bronco: ARB’s Under Vehicle Protection System / Skid Plates 20220623_192539
Ford Bronco Armor for your Bronco: ARB’s Under Vehicle Protection System / Skid Plates 20220623_192548
Ourbroncolife
Sean
Greenville, SC
youtube.com
Front Panel: Engine
Additional Features
Additional Notes:
Part # 5480100
Awesome!
buzpro
Binky
Tacoma
1. how do you reach the oil pan drain plug?
2. how much does it all weigh?
3. how much extra for protecting the gas tank?
Thanks.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Some side shots of how the transmission skid plate sits? If it hangs low or if it is tucked up inside the frame a little? How far back does the transfer case skid go? I feel the shock transfer case skid should extend back farther. Thanks for the pictures, nice to see some welds and bolt location. Any fitment issues?
Odd Ball
Cali
HD Vett Mustang Jag 911 (2)450SLs VWcab Blzr Fiat
Front Panel: Engine
Additional Features
Additional Notes:
Part # 5480100
When will ARB have a sale, I’ve got a whole list of stuff I can’t live without. (But I’m cheap)
Villagevip
James
The Villages, fl.
"68" "72" Broncos, sadly sold, back in the day
As a non off roader, only Florida beaches(when I get a Bronco) ...Think, this smooth undercarriage can, or will improve fuel economy on the turnpikes, and freeways? If so, will there be a thinner gage, less weighted version? : )
