Deleted member 9326
Guest
Am I the only one who doesn't give a crap what the mileage is?
Of course that might be because I drive an '05 2500 Suburban 4x4 with full tow, 4.10 gears and an 8.1L that makes a slurping sound as it goes down the road!
No interest in free money and greater range between filling-up?
bajabronco57
Nor Cal
4Runner
While MPG is important to me, I'm far more concerned with miles per tank. I plan on doing longer trips through the desert and I'd prefer not to have to rely on dump cans just to keep up with other vehicles. I was expecting "about" 20MPG so I'm not really moved either way.
TheRealCobraBurnout
Matthew
Wyoming
www.youtube.com
2003 Ford F150
From a Badlands on 33's
Ford guy said it was running 75 mph on hwy - they drove 4 hours to get there.
Is this supposed to be good? Doesn't seem good. But I always seem to have the least fuel efficient vehicle in town.
buzpro
Binky
Tacoma
A tiny 2.7L engine that is not fuel efficient .... how FORD like
just why exactly are these small engines in the market place? why not just do a normally aspirated V6 if consumption is the same ?
BroncoRevital
Zak
Toyota Tacoma, past; 94 FB, 86 FB, 84 Bronco2
Eh not horrible. When you’re driving a brick over 55 miles an hour it’s going to drink a lot. I won’t be surprised if a non Sasquatch Bronco 2.7 gets 20 miles per gallon highway and that will be great.
rugbysecondrow
Pauly P
north carolina
1964 C-10 stepside
I care less about MPG and more about miles per tank. Stopping to refuel is a waste of time.
BroncoRevital
Zak
This doesn’t really make sense to me. They are still one in the same or at least effect each other. MPG is a key factor in this. I mean sure get a giant fuel tank but that will make it heavier and thus use more fuel so....
rugbysecondrow
Pauly P
north carolina
1964 C-10 stepside
The mpg is a means, or variable, to help achieve the miles per tank. Of course I desire mpg to be improved because that helps achieve my goal as well, but that is not the sole metric I care about.
Bdisco
Flashing my lights behind you, MA
‘88 911,‘15 Chevy 2500, ‘24 Acura Integra Type S
What I have read is that it will run on 87 but if you put super (only 91 here in Kalifornia) the engine will respond to a degree. I'm very interested in a factory tune but only if it is 30 + HP not 5-10 then its nothing. I will put 91 in it anyway. 20 cents a gallon X 16 gallons= $3.20 more a tankful who cares I just spend 45k on what I hope will be my dream SUV
The wife’s Mazda CX-9 gets 227hp on regular, BUT 250hp if you use the good stuff. 310 torques with either. If the Ford gets a bump like this then she gets top tier fuel all day, every day.
Hopefully Cobb comes out with a tune so we can chase down the hemi rubies.
Compta38
Alabama
Ford Fusion
/cries in Sasquatch.
Wanted33
Down south in Dixie
Based on trip time that's averaging ~30mph. I'd imagine a lot of highway use mixed with a lot of idling.
I agree. I don't think we can put much stock in numbers we see on these Bronco's. With my 2.3L Ranger much of the mpg's depends on the amount of go peddle one uses from a dead stop. Also, a lot does depend on the set up of the Bronco also. Much like the mpg numbers we get from the gubment, we'll have to wait and see what we get on our Bronco's after we get them home.
Pancho Kornwallace
Pancho
Mustang
HUH?
1. Have you ever actually driven a Jeep Wrangler?
19MPH would be very efficient v a Jeep.
Remember that the four door is a very heavy vehicle that is just on the limit of its weight class. I expect my 2-Door with the 4 cylinder and 30s will do 3-4MPH better. Which would be awesome and would be way more efficient engines than Jeep.
2. Also did you check the HP and Torque on these things? Hint: They are very good. It is not 1976 anymore. Size of engines are getting smaller, but power output and efficiency is getting better. Ford now sells a 3-cylinder for the Bronco Sport and AWD Escape. It works great.
3. And how about checking the sales of Ford F-150s and Rangers with smaller engines? HInt: the sales numbers are excellent. Doors knows what it is doing.
ronstar
Ron
Illinois
F-150, Jeep JL
I have a 2017 F-150 3.5 on 32" KO2's that weighs about 4700 lbs getting 19mpg.
I'm getting a 2 dr 2.7 Badlands on 33" KO2's that weighs about the same. I suspect I'll get around 19 mpg on the Bronco too.
  • Like
Reactions: abe
