30lbs Propane Tank Mount (PICS INSIDE)
OriginalC
Portland , OR
2024 Badsquatch
Hey everyone. I'd been looking for a while for a solution to hauling around a 30lbs propane tank. I had to kind of think outside the box here and this is what I came up with.
PARTS:
1 - Built Right Molle panel https://builtrightind.com/products/...nel-system-ford-bronco?variant=46279917568214
2 - Ace Manufacturing 30lbs propane tank bracket https://utsparts.com/products/metal...f3nDoNuAMLVjugf7F4o4oUdyp5EyPzIvkSX1zeDRZlvZw
Let's start off with the propane tank beside the panel. Needed to see where it would line up best.
Ford Bronco 30lbs Propane Tank Mount (PICS INSIDE) IMG_6299
After that we had to get creative with the mounting hardware as it lines up almost perfect however it's best if you have some spaces and washers etc.. The side are pinned against each other oppositely so they really can't move.
Ford Bronco 30lbs Propane Tank Mount (PICS INSIDE) IMG_6302
Ford Bronco 30lbs Propane Tank Mount (PICS INSIDE) IMG_6301
The Built Right Molle panel allows this tank to hover just slightly above the cargo liner bump out for a near perfect fit.
Ford Bronco 30lbs Propane Tank Mount (PICS INSIDE) IMG_6310
Finally we have the finished product.
Ford Bronco 30lbs Propane Tank Mount (PICS INSIDE) IMG_6314
Ford Bronco 30lbs Propane Tank Mount (PICS INSIDE) IMG_6313
The fit and placement is perfect while being extremely sturdy. Perfect solution for what I was looking for.
BroncoA512021
Long Island, NY
www.facebook.com
2021 Ford Bronco OBX
30lb inside the car? Never a good idea…..
73Corvetteman
Duane
Hudsonville, Mi
2023 bronco
Although I love your ingenuity consider this:A 30 lb propane cylinder can typically withstand temperatures up to about 120°F (49°C) without risk of failure. However, it's important to keep it in a well-ventilated area and avoid exposing it to direct sunlight or high heat to ensure safety. On hot days I would not leave in Bronco. It can easily reach 120° or more and I don't want to read about in the obituary.
OriginalC
OriginalC
Portland , OR
2024 Badsquatch
Thanks for the heads up! My personal use case for this is simply to transport my propane tank from my back yard fire pit to the gas station to get it filled and then back at home. It's a 10 minute drive to the gas station by myself (no kids), it gets filled, and then back home to the fire pit. I wouldn't take this on camping trips or transport it for more than an hour or so at a time. I couldn't stand using straps to hold this down as it didn't feel as safe.
Thanks for looking out, if I was using this normally as a transportation unit your advice would have been critical, and still is critical for any on lookers.
Bronco Naughty Pines
Jerry
Scottsdale AZ
2022 Bronco
I love my propane fire pit.
I use the milk crates, it work fantastic with room to help snug it in with other stuff, so milk crate to molle with cut to fit strap, than strap through the top tank holes. The longest trip 1.5 hours door to campsite. That time my air-conditioner friend brought his leak detector. No leaks.
But I totally agree short trips Cool weather. Here in AZ summer that would be news a 6pm.
vrtical
Doug AI
GSMNP, TN
Fords
I dunno I just use my cargo net or bungi cord.
