2025 Outer banks saskwatch TOAD
Towboy
Summerland Key FL
2025 Ford Bronco, 2019 Ford F250 king ranch
Going to pull behind my motorhome has anyone run wires from front bumper 4/6 pin plug to rear tailights? Just wondering the routing of the wires.
Thank you John
dgorsett
colorado
F250, Mustang, Explorer
I ran mine from the bumper, behind the grille to the engine compartment, down the firewall behind the fender liner and along the outside of the drivers side frame rail with some factory wires. Enclosed in split loom. The hardest part was behind the grille, clearances are tight. Watch clearances back at the muffler too.
Towboy
Summerland Key FL
Yes I saw the factory harness going rear I'll zip tie to that thanks. How did you mount the plug, blue ox shows drill 1 1/4 hole in bumper i really don't want to do that. Thanks for your help it's appreciated!
dgorsett
colorado
Originally I just had a 4 wire flat so it just kinda dangled in the intercooler opening. Now I have a 6 wire and an after market bumper. The six wire fit nicely into a parking sensor hole I didn't need. I also mounted my breakaway in an unused sensor hole, Were I mounting in a standard bumper and unable to use a sensor hole I would probably mount both in a piece of angle bolted into the intercooler opening.
Ford Bronco 2025 Outer banks saskwatch  TOAD 20240101_125325
Towboy
Summerland Key FL
I see looks real good thanks
Towboy
Summerland Key FL
Was there a straight shot up to the tailights? I know they must be removed to splice in the resistors..
dgorsett
colorado
You don't have to remove the lights, just the black plastic access covers. Two ?? bolts and 4 PITA push pins each. Your wire come up from below. I used the Curt plug in harness.
Ford Bronco 2025 Outer banks saskwatch  TOAD 20250517_110629
I have a hold of the wire loom here
Towboy
Summerland Key FL
Got it thanks
Towboy
Summerland Key FL
You talking about this setup? It works with red stop and yellow turn signal led lights? Or will the motorhome just use the red stop lights as the blinkers also on the bronco cause only 4 wires.
Ford Bronco 2025 Outer banks saskwatch  TOAD Screenshot_20250517_140310_Amazon Shopping
dgorsett
colorado
Kinda. Curt makes two. One for Broncos with LED and one for those without, mine was without.
Towboy
Summerland Key FL
Ok I have led lights red brake yellow turn signal i just don't want to hit the brakes on motorhome and yellow lights up for stop i will reach out to curt on Monday won't bother you anymore! Thanks again.
dgorsett
colorado
All good. Safe travels.
