2025 Ford Triple Zero finance and rebates
2021WILDTRAKCDH
Topher
SoCal
2021 Bronco Wildtrak
Does anyone know if Fords triple zero finance applies to 2025 Bronco Raptors ? Any rebates on 2025 Bronco Raptors? Dealer isn’t sure …lol.
Thank you
2021WILDTRAKCDH
2021WILDTRAKCDH
Topher
SoCal
Thanks Brother , You always have the right and correct information!
Do you know of 2022 Bronco Raptor TPMS sensors work on 2025 Bronco Raptors ? I have the RTR evo 6 on my 2022 and have a 2025 arriving and want to do a simple swap …
Tirerack says it may be an issue…2025 have a new part numbers for the TPMS.
Thanks again.
I’m assuming you have or had a 1098 …Still miss my 1098 …traded it for a panigale and only got burned thighs and less enjoyment …loved the dry clutch.
Cheers
Ducati1098
Thanks again.
Cheers
No problem.
Not sure off hand about the sensors. But I’ll look into it and let you know.
And yeah I had a 2010 Streetfighter, got rid of it a few years back and miss it a lot. It was an absolute blast, just never had time to ride as much as I wanted to.
Ducati1098
Doesn’t look like they will work, Ford did change them.
2022 uses 315 MHZ, 2025 now uses 433 MHZ
2021WILDTRAKCDH
2021WILDTRAKCDH
Topher
SoCal
Ford Bronco 2025 Ford Triple Zero finance and rebates IMG_5844
I have a lot of love for Ford products …why would a manufacturer change the frequency? Does it have additional features like tire temp etc…? Ford makes it hard sometimes.
Ducati1098
I have no idea
Charley
Muttonville
2024 Badlands Hot Pepper
Jeep changed frequency in 6/21.
a little research shows most auto manufacturers changed Tire Pressure Monitoring System (TPMS) sensors from 315 MHz to 433 MHz.
TXBronco1313
Almost always Ford Performance line is exclude from promotional rates
SHANUT
Craig
Hermann, MO
Thank you
You need to find a different dealer. That one is a shyster. They can look up all of those things on the system and get accurate information immediately.
