2025 Bronco base build
jwhisl
jwhisl
James
Oklahoma
2025 Bronco
Double check with those in the know, but I don't believe there is any reason to swap to the Sasquatch UCAs, they are the same as regular.
I can confirm that the lug nuts and upper control arms are the same
jwhisl
jwhisl
James
Oklahoma
2025 Bronco
I did some sound deadening over the weekend and installed the flowmaster outlaw catback. Too loud for my taste so I'm looking to trade for the flow fx or similar
Ford Bronco 2025 Bronco base build IMG_20260405_163018
jwhisl
jwhisl
James
Oklahoma
2025 Bronco
Panda Motorworks
O'Fallon MO
Very interested! Waiting for tune options and an intake setup for the 2025. I'll check out the site to see what else you offer.
Awesome!! You can always message us if you have any questions!
jwhisl
jwhisl
James
Oklahoma
2025 Bronco
I scored a capable bumper with foglights, wiring, and skid plate and got it installed yesterday. Today I started installing my 3d printed door pockets. Tomorrow the headlight switch with foglight buttons arrives
Ford Bronco 2025 Bronco base build IMG_20260412_142453
Ford Bronco 2025 Bronco base build IMG_20260412_142510
jwhisl
jwhisl
James
Oklahoma
2025 Bronco
Installed a protester protector and did a little more sound deadening in the back behind the subwoofer enclosure. I also made the hole a little larger and installed a CT Sounds Bio 8. 300 watts rms and can be ran by the factory amp until I get a full day to run my power wire and install a real amp.
Ford Bronco 2025 Bronco base build IMG_20260420_081314
Ford Bronco 2025 Bronco base build IMG_20260419_191557
jwhisl
jwhisl
James
Oklahoma
2025 Bronco
For those wondering, the factory enclosure has just a hair under 4 1/4 inch depth. That limits us to low power and shallow subs but there are a few out there.
Ford Bronco 2025 Bronco base build IMG_20260420_195336
23OBX2.7
AB Canada
2023 Bronco
I don't necessarily have a need for the lockers right now so they may never happen. I bought it from a dealer, not built on the ford site. I would have loved to customize one but where's the fun of having everything done for me?
IMO as an off road dirtbiker any terrain thats extreme enough for lockers will be very hard on the overall vehicle.
jwhisl
jwhisl
James
Oklahoma
2025 Bronco
What are the Sub specs?
300rms/600peak. I've been using this brand for years and they are underrated on power. I can get the rest of the specs for you real f you need them. Also if you move up to an 8" you will want a gasket or adhesive between the box and sub. The original screw holes will leak air and make noise.
jwhisl
jwhisl
James
Oklahoma
2025 Bronco
Brand new tires this time. 285/70/r17. I got a great deal at $800 installed for the set. Still need to get the spare done but they had to order it. Anyone got an extra TPMS sensor?
Ford Bronco 2025 Bronco base build IMG_20260524_133832
jwhisl
jwhisl
James
Oklahoma
2025 Bronco
A couple weeks ago I finally got around to taking the entire top of and getting my Temu rear speaker pods installed with some Sony ES series 6.5's No pictures of the pods yet but they are identical to the Mabett option. Also got my Temu armrest cover. It fits pretty good for Chinese plastic! It has a nice rubbery feel to it. For less than $20 I really can't complain.
I was without my bronco for a few days when the driver side CV knuckle decided to separate at the diff. The dealer tried to say I hit a rock but honestly I think they were just trying to get out of the repair. It was all covered under warranty but just in case I went and ordered some skid plates for the lower control arms. Considering I drove it another 140 mi with no issues after my last off-roading, I really don't think I damaged it.
Ford Bronco 2025 Bronco base build IMG_20260517_104553
Ford Bronco 2025 Bronco base build IMG_20260517_104451
Ford Bronco 2025 Bronco base build IMG_20260527_070104
jwhisl
jwhisl
James
Oklahoma
2025 Bronco
jwhisl
jwhisl
James
Oklahoma
2025 Bronco
Over the weekend I made some good progress on my audio upgrades. Onefaststang custom designed and 3d printed some dash pods for my Dynaudio 3-way set and I was blown away with the quality and fit! I highly recommend messaging him if you are looking to take your sound system to the next level.
Ford Bronco 2025 Bronco base build 1000010986
Ford Bronco 2025 Bronco base build 1000010981
Ford Bronco 2025 Bronco base build 1000010982
jwhisl
jwhisl
James
Oklahoma
2025 Bronco
Onefaststang included the screws, clips (and extra clips), and threaded inserts in the mounts. The grills are held on with high quality magnets to give a nice OEM factory look.
Ford Bronco 2025 Bronco base build IMG_20260603_213705
Ford Bronco 2025 Bronco base build IMG_20260606_071357
Ford Bronco 2025 Bronco base build IMG_20260607_092944
Ford Bronco 2025 Bronco base build IMG_20260603_213741
Ford Bronco 2025 Bronco base build IMG_20260607_140228
