2024 Big Bend Sasquatch Build | 2DR 7MT
Bronco_MI
Greg
2024 Bronco, 2016 Ram, 1991 Sierra, 1969 Firebird
Hey guys, figured I’d make a thread to follow the build of the Bronc and update it with pictures and YouTube videos of my installs! Thanks for any support 🤘🏻
My New 2024 Bronco Big Bend Sasquatch !!! 2024 Ford Bronco Review & Overview
Following. I got mine about a week after you. Very similar configuration. So far, I've added the Havoc Offroad rockslide/step and a Black Diamond grille. I'm working on the DV8 F15 front bumper install at the moment.
Ford Bronco 2024 Big Bend Sasquatch Build | 2DR 7MT IMG_8534
Ford Bronco 2024 Big Bend Sasquatch Build | 2DR 7MT IMG_8311
Jack D
Jack
Central New Jersey
05 Jeep Liberty 6MT, 93 Explorer 2dr 5MT
OP- also following, getting inspired to do more mods on my ‘22 Big Bend. Great build so far!
Bronco_MI- love the Black Diamond grille! Was it a simple swap with the Big Bend’s, or were any modifications needed to fit?
Bronco_MI
Greg
Easy swap. You'll remove the plastic cover over the top of the grille (located) under the hood. Then remove four bolts that hold the grille on. Then pop the grille off - there are prob 16-18 locations that have a clip and those locate into slots in sheetmetal behind the grille to hold it in place. There is a bracket on your grille that you'll need to transfer to the new grille. And of course, those metal clips. You'll also need a new set of badge letters - you can get them in any of the standard Bronco colors.
SierraBronco
Two door manual is rad
