2024 aux switch wiring
BDEG Kyle
Kyle
Atlanta, GA
Honda civic
I was unable to find the AUX switches wiring like the other years in the owner manual. It does not have the diagram. Would it be the same as the other years.
Ford Bronco 2024 aux switch wiring IMG_8562
Ford Bronco 2024 aux switch wiring IMG_8563
Cux211
NE PA
19 ram 2500 Laramie blackout cummins
Does anybody have a link to the diagram I’m in the same boat my 24 has no references to it
xHarris93x
Cory
Pennsylvania
2024 Ford Bronco
I'm not sure if the colors are the same on all broncos but I went and tested every wire to switch number. So hopefully this helps also switch 1 had a thicker wire on it the rest were the same
Ford Bronco 2024 aux switch wiring 20240718_090928
J-Lugster
Ancaster, Ontario
2024 Ford Bronco Wildtrak 4Dr Oxford White
Here is the digital version.
Ford Bronco 2024 aux switch wiring Aux Switches Wire Colour codes
RaefordRider
Tim
Raeford, NC
2024 Black Diamond Bronco
I've got my glove box out, looking for wires...can someone point me in the correct direction? I don't seem to be finding any...maybe I'm blind in one eye and can't see out the other?
Deadpool392
New Bern, NC
2025 Marsh Gray Bronco Raptor, 2020 Gator JTR (retired)
They are a pain in the ass to find, mine were wrapped up in wire looms with very little showing. I was wiring up for the rear and had to pull the trim on the floor to trace it back to behind the glovebox, it was taped up higher back to the loom. I would start by removing the plastic trim over the speaker and search there for the wire loom, have a good light, they looked the same in my Bronco (orange/white to the rear, orange/gray to the roof)
RaefordRider
Tim
Raeford, NC
Thank you. I'm just about ready to just run my own wiring. I wish they still used screws on trim strips <whine, cry and snivel>
