2023 Outer Banks Build 35’s, etc
JTM
Ohio
2023 Bronco Raptor
Here are a few pics of my 2023 Outer Banks and details.
2.3L Auto
4.27 gear w/ rear locker
Aux switches
12” screen with Nav
2” Rough Country Spacer lift
315/70/17 Nitto Ridge Grapplers
17” Black Rhino Arsenal w/+12 offset
Rough Country spare tire relocator/reinforcement
“Superchips Flashcal for Bronco” that doesn’t work.
Crash bars removed
Rhino USA recovery kit
Overall I absolutely love it. All the indecision and studying of these forums seems to have paid off. Rides close to stock with very little road noise. This is my first ever set of Nittos and they look and ride amazing. I don’t really have any complaints or regrets right now other than the Flashcal that says it’s not compatible when I hook it up.
Ford Bronco 2023 Outer Banks Build 35’s, etc DB152084-1A7E-4DE4-A34C-463EFAA0D358
Ford Bronco 2023 Outer Banks Build 35’s, etc B4A86A72-77B0-4E09-A0E4-4FE5E494BE38
Ford Bronco 2023 Outer Banks Build 35’s, etc 6C96A519-4EB5-4A4E-A4FF-4F51D7A367C6
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
Looks good!
  • Like
Reactions: JTM
Baja Bronco
2Sun AZ
22 Ford Bronco, 20 Ford Raptor
Looks good. What do you mean "Superchips doesn't work"? What happened?
  • Like
Reactions: JTM
JTM
JTM
Ohio
2023 Bronco Raptor
It gives a message that it’s not compatible with my vehicle. I’ve emailed them 2 days ago with no reply. Maybe it’s my fault but their website only gives the option for model year21-22 and if you select 2023 Bronco it says no products available. I assumed this was an issue with them not updating their website for this product since 2023’s have only been out a few weeks. I update the product on their website also.
JTM
JTM
Ohio
2023 Bronco Raptor
Update: Superchips answered the phone after 33 minutes on hold. The product does not support the 2023 Bronco and they don't have an upgrade yet. So I filed for a return and purchased the OBD link EX for the Forscan program for windows.
CMillBronco
Craig
2024 GMC HD 3500 AT4, 2022 Toyota Tacoma TRD
Nice build, we have a A51 Lux 2.7 auto with 4.27 locker on order and I'm doing a very similar build. I have Sasquatch wheels/tires and Bilstein 5100's sitting in the garage already. How is the 4.27 ratio doing with the 35's and auto trans, that's the only thing I've been concerned with?
  • Like
Reactions: JTM
JTM
JTM
Ohio
2023 Bronco Raptor
So as you’ve read there is no programmer for the shift points or tire size yet. With that said it does amazing compared to what my JK did after installing 35’s. Of course we are talking about a 10 speed compared to 5 but it really does shift smooth. I actually prefer the economy mode because the transmission is so, so smooth in that mode. It’ll go if you press it down but it doesn’t jerk you back and forth like normal mode might. In my opinion the 4.27 is perfect for 35’s.
JonFord1972
Jon
Belmont NC
2023 2dr Black Diamond 2.7L, advanced 4x4
If you are still looking for a programmer, the SuperChips Flashcal, is updated to do most of the common changes. I also have a 23 (Black Diamond 2dr with 37's) I got rid of the dbl honk, set tire size to 36.25 and can run fog lights with high beams.
azuano3654
Salt Lake City, UT
Mustang Mach-E
The Ford Performance tuner/calibration does allow for tire size changes. It also gives you the increased torque/HP calibration. I've found it to be very much worth the cost if you're interested.
Hinezy
Richard
The Coal Region of PA
2022 Bronco
I also have the Flashcal and now that I have the fog lights on with the high beams, I now have to manually turn the fog lights on with each start of the Bronco. It used to stay on when turned on. Are you experiencing this?
JonFord1972
Jon
Belmont NC
Yes, I am, I leave mine in auto, so they come on when it gets dark enough and stay on when the high beams turn on, but I had to do that since I took delivery. I was hoping they would come on just like DRL but they don't.
