redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Mind posting part numbers when you get a sec?
rtazz17
Rob
Connecticut
2022 Ford bronco big bend
Will like to see after raising rear up and down a hundred times.. hopefully it remains the same.
redone17
Cold Spring, NY
Not sure why that would make a difference. It's not like the 2021-2022 started out this way. I am just curious if one can buy new side windows and they just click into the 2021-2022 tops.
JohnnyBronco
Pennsylania
X4
Yes. Absolutely. The covered wagon top is still a big no for me. But the priority was fixing the wavy windows which was biggest complaint they got on surveys. Baby steps with Ford.
No recall for sure and if we wanted to buy replacements they would not be available as parts or would not fit 21-22. Only available as set with an entire $5000 roof (just sayin')
Ksjrb03
Tx
F250
I was told the crappy fastening was an issue and would change to something more robust. Therefore you would be correct, not backwards compatible. That’s why I asked OP to verify if they changed.
Area51BS
Ron
Badlands non SAS 4dr 2.3
Windows for 23 are listed on Ford site. Also fit 21-22. But no way to know which ones you would get unless part numbers are different on an actual 21-22.
Ford Bronco 2023 Bronco Soft Top Window Seems Less Wavy DE92B8B2-8A10-430B-A3C8-2CB7D831603F
Ford Bronco 2023 Bronco Soft Top Window Seems Less Wavy B0C90734-56B5-4A4E-A948-9EF43E99573E
Ford Bronco 2023 Bronco Soft Top Window Seems Less Wavy 13EF436E-9A42-4326-A5EE-9B5DA3283E72
redone17
Cold Spring, NY
Guess we’ll have to compare part numbers…
NaMinesClarence
Northern Metro MN
2022 Badlands Sasquatch
My stitching is coming lose on the rear of the portion of the soft top, maybe they will replace it with a new one 😍 I don't see how they could fix it without deconstructing the top. Might not be cost effective.
CT203
Connecticut
'13 JK
Took delivery of a 2023 Badlands on Monday, and the soft top side windows are the least wavy I've ever seen on a new Bronco. Did I just get lucky? Anyone else taken delivery on a '23 and notice this? They'll probably get wavy as time passes anyhow, but still.
Wow they’re beautiful! My ‘23 has the typical waves. I thought I kinda missed the Jeep wave but now I have the Bronco waves.
JimboSlice
South Lake Tahoe, CA
2022 Ford Bronco Outer Banks 2018 Audi Q7
Mine were wavy the day I picked it up and the first thing I did was scratch the hell out of them trying to clean them. I would buy these in a second if they're an upgrade.
ColeTrain84
Cole
Minnesota
'22 Bronco Badlands
mine were flat on my 2022 Badlands when i first got it. Not anymore.
