2023 Bronco rear sagging under load... solution?
BleednBlue
Rich
Wentzville, MO
2023 Ford Bronco; 2018 4Runner; 2008 GX470
Firestone makes airbags. Think they are called "Air Helper Spring Kits".
Aonarch
Jack Hoff
MT
‘23 Bronco OBX 2DR Lux 2.7, ‘24 V60 Polestar
JediMcMuffin
Tommy
2026 F-150 Tremor 401A
You could remove the spare tire and carry a patch kid. That would remove ~70lbs or so behind the rear axle. It would also let you eliminate any hitch extensions you might be using and reduce that lever effect.
I mean, tongue weight is tongue weight. There are a couple threads about sumo springs.
Alanp970
Alan
2023 4 Door Base Sasquatch Hardtop
I installed the 1-1/2” perch collar spacers from Broncbuster front and rear on my Sasquatch and it really firmed up the ride (in a good way). It carries a load much better, brake dive is reduced and just doesn’t feel as wallowy. I’m really happy with it
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
We have coilovers that won't work....
needs some punctuation!
we have 'coilovers that won't work'
or
we have coilovers! that won't work!
Muffin Top
TX
JK, MK, KK, TJ, DN
Aonarch
Jack Hoff
MT
or
I probably wrote that on my cellphone while sitting on a toilet. So I'd say A+ for effort.
Gargantua
Chicago
M1083A1
You could get a arb bumper and winch and it’ll be level…​
