2023 2.3 AC just died - advice needed
dejones64
Dan
MN
Bronco 2-dr Black Diamond
I know the feeling (I was born in MN). Left in 1995 for Scottsdale, moved to SoCal in 2000, and to ID in 2016 (got tired of the heat). Snow is not that bad here in comparison to MN.
Interesting, I was born in Scottsdale and moved to MN. Getting close to retirement and considering back to AZ (my mom is there), but the heat is brutal yes. Considering WY but brutal winters, so maybe summer there and AZ in the winter. Does ID get the crazy winds like WY?
Danielsand
Daniel
Idaho
'21 OBX SAS
Not even close. I am in a deep canyon. We get wind, but nothing like flats in WY. My main house is at 4500' (I have 1100 acres) surrounded by BLM. Only about half a mile from pavement. MN winters are bad (I remember some Januarys not seeing sunshine for a month or more). Not so bad here. Sunny (warm in comparison to MN) winters, and not much work on the ranch. I "off-road" on the horseback (not in Bronco). Winter is my favorite season here (same in AZ and Cali but definitely not in MN). The only thing I enjoyed in MN was snowmobiling all the way to Stillwater and Hudson. The rest sucks, especially the winter traffic in/around Twin Cities.
dejones64
Dan
MN
Very nice! Yes MN seems gloomy at times, not much sun. I could deal with some snow, but not the windchill and freezing temps.
Danielsand
Daniel
Idaho
'21 OBX SAS
I am not a skier, but I've seen many times people sunbathing at ski lodges. It's like that here. I can be on the horseback in January at 7-8000' in a t-shirt. Sun is VERY strong at that elevation, and most of the time you're above clouds. But after the sundown, you better be below 4000' in a shelter.
MrBell
MrBell
Seattle
Bronco 4 door OBX
Update: My Bronco has a failed transducer that's not engaging the AC clutch (their words). Thankfully the part is available and I should be back on the road Monday.
Bikeric
Tulsa
2022 Badlands LUX on 37's
When the AC in my 22 2-door quit working I discovered the stretch-to-fit belt had come off. Replaced the AC belt and Walla..... AC works like a champ. The Dealer didn't carry the proper belt and had to order it, so I just bought one from O'Reilly's.
a94cobra
TX
2022 Bronco
My 2.3 is doing something wierd. Every now and then it stops working. But throws the P0532 code. Low PSI on circuit A. So I checked the charge pressure and it was fine. Next day or an hr later usually starts working again. I'm thinking the sensor might be failing.
dpAtlanta
North of Atlanta
2024 Badlands & 2019 GT350
I have lost the A/C in my 2019 GT350 five times in 56,000 miles!
I hope the Bronco does not follow suit!
a94cobra
TX
2022 Bronco
What did they determine it was?
dpAtlanta
North of Atlanta
Which time…?
Evap - High Pressure hose - compressor - & lack of proper system flush for two of them.
