2023 2.3 AC just died - advice needed
MrBell
Seattle
Bronco 4 door OBX
The AC in my 2 door 2023 Badlands just quit working, blows hot air.
Before scheduling a repair at the dealer is there anything I can check on my own? I did push all the fuses down to ensure they are seated. Is there a specific fuse for the AC? I've searched but not found it.
Appreciate any advice.
Valhalla
Valhalla
Chattanooga Tn
Should be warranty item if you are not over miles. Make them fix it!
MrBell
MrBell
Seattle
Bronco 4 door OBX
Yes, it will get scheduled tomorrow at the dealer. Just curious if there's something simple I should look at and avoid making the trip.
Valhalla
Valhalla
Chattanooga Tn
look at the plug on the compressor make sure it is securely seated.
dejones64
Dan
MN
Bronco 2-dr Black Diamond
Keep us informed on what the dealer finds please. My 2022 2.3L manual 81k miles, blows cold randomly but mostly hot air. Need to make an appt w/dealer yet.
In the winter I have the heat on, sometimes it will blow cold. I move the dial over to the cold side then back to the hot side then it will start blowing warm. Odd.
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
just had mine repaired last month. crack in the evaporator box at the firewall attachment. took a couple of weeks to get the correct parts. my local dealer did a stellar job keeping us informed
I have to recharge mine every Spring, it takes half a can of R1234. Blows cold all summer. Then next Spring - low again
I’m sure there’s a small leak somewhere that only appears when it gets cold and contracts or something. But so far it’s been relatively tame and easy to adjust for since I’m out of warranty and don’t feel like tearing the dash apart to get at the evap or anything
dejones64
Dan
MN
Makes me wonder if I have a crack/leak somewhere. Just got back from a 3-week overlanding trip out west. Dirt road trails in Utah were brutal, everything rattled.
Lcubed
l
UsA
the dealer mentioned they've seen several bronco's and F150 with this failure recently, but mine was the first 7MT
jtpasto
Jerome
Salmon Idaho
2022 Bronco
I also interested in what the dealer says. 2022 2dr Black Diamond 7MT with 91000 miles. The AC is intermittent, sometimes it is cold and sometimes it is not so cold.
MrBell
MrBell
Seattle
Bronco 4 door OBX
Mine has only 37K miles. Thankfully I bought an extended warranty from Grainger. AC was working great, then died. Hope to know more soon.
dejones64
Dan
MN
Advice for nonop A/C in Bronco? Move to Alaska. Great trails, no A/C needed.
I love this idea, but I can't stand winters anymore.
Lcubed
l
UsA
didn't they issue a heat advisory last month up there?
( i remember visiting the scandanavian countries during their first heat wave back in the 80's. no A/C and all the buses had windows that didn't open.
SAUNA!!)
Danielsand
Daniel
Idaho
'21 OBX SAS
I know the feeling (I was born in MN). Left in 1995 for Scottsdale, moved to SoCal in 2000, and to ID in 2016 (got tired of the heat). Snow is not that bad here in comparison to MN.
