2022 Wildtrak Speedometer reading 2mph fast
Scott R Nelson
Meridian, ID
That's normal for every car.
This is the correct answer. What other cars have you owned that were more accurate?
For the record, of the 22 cars that I've owned, only one has had an accurate speedometer, my 2014 Escape. The Bronco seems to be off by 1 mph somehow, rather than by a percentage, when compared to a GPS unit. Years ago I had a 1980 Suburban that was off a good 15%. I had to put a gearing adjuster on the speedometer cable of that one. I also owned a 1993 Ducati that was reading about 20% high, but I didn't have a GPS unit at the time to find out how bad it really was.
Freedom5
Freedom
Snohomish Washington
Classic mini cooper
I was reading 3mph fast on my sasquatch. I put 37s on and mine is spot on now.
Deleted User 5719102
Who's
On a Lake
22 2dr
Ford Bronco 2022 Wildtrak Speedometer reading 2mph fast R (19)
AKBronc49
Russ
Anchorage, Alaska
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Bikes are notorious for being off. I had a ZX6R once that I topped out around 173 or so on the speedo but the GPS said 156.
