2022 Big Bend Wheels - Will They Fit?
Duffy705
Sudbury, Ontario, Canada
2022 Bronco Big Bend
Looking to pick up a set of ProComp wheels. The Series 35 Predator have been what I've wanted for a long time, and I notice they make a 6x5.5 bolt pattern. What I don't know is the offset/backspacing ... is this aggressive, stock or too tight?
  • Wheel Size: 17x8.5
  • Bolt Pattern: 6 on 5.5
  • Offset: 0
  • Backspace: 4.75
Going to have a set of Nokian Outpost 315/70/17 mounted on them. I am also lifted 2" with a ReadyLIFT spacer kit. Just curious how this would look.
Thanks in advance !
Ford Bronco 2022 Big Bend Wheels - Will They Fit? procompwheels-2635-series-a_15
F OR D
BD Green Machine
0 offset lots of poke, like over 2". stock offset is +55
Duffy705
Hmmm, so Squatch, or aftermarket fenders would be needed then, yes?. Or just 2" over my stock (+55)
UNBROKN
Central Virginia
04 F-350 CC dually, 97 Infiniti QX4, 21 Bronco BD
Those wheels will look great. My wheels are +18. I put the grabbers back on there until I can save for lift and tires. Very little poke. Yours will poke more. When I go bigger and wider, I will add the squatch flares.
Not great pics, but here is the poke on mine
Ford Bronco 2022 Big Bend Wheels - Will They Fit? 20220314_122213
Ford Bronco 2022 Big Bend Wheels - Will They Fit? 20220314_122149
Ford Bronco 2022 Big Bend Wheels - Will They Fit? lizzy 3
BLKNWHT
Adam
20220 bronco
I put on 315/70/17 Method +25 and they work great. Only had to remove crash bars. Big bend.
BLKNWHT
Adam
20220 bronco
New to this site so not sure how to post but wanted people to know to go with them.
‘21OBX
90Bronco19
2022 bronco outer banks
What’s the center bore size that’s going to be important. Too big and you can get adapters. Too small and it’s a no go without some spacers and stuff.
BLKNWHT
Adam
20220 bronco
I’m not sure. I just went with the 305 Method 17” with the +25 offset they offer and they are perfect. I almost ordered the 0 offset thinking that keeps them in but a friend told me you need the positive to keep them in and the 0 offset will stick out too far for most.
‘21OBX
90Bronco19
That was for the OP before he ordered the rims and had an issue.
BroncoBarn
Illinois
2002 Wrangler
Are there any issues caused with the factory warranty when changing wheel and tire size?
Duffy705
Brodozer made me laugh pretty damn hard. Seeing as how my Big Bend is Cyber Orange, it actually works 🤣. I ended up going with 17x9 0 offset TTX MOABs in the machined black / bronze tinted. I will be opting in for the much wider fenders (non Ford part, they're Raptor-esque) to cover them.
All I have left is running boards and I'm done
Duffy705
None at all. My dealer is pretty good and even let me lift it (spacer only, no component changes) while retaining my warranty. Think of it this way ... when you buy winters, you'll 99 times out of 100 see people change the wheels to steelies. That means dealers would be voiding warranty as they package them in. You'll be ok 🙃
