Deleted member 18388
Guest
Nice to see more information on some of the systems (auto high beams, auto hold brakes, intelligent access, etc.). Still bummed it looks like adaptive c.c. probably doesn't have lane centering?
These options are not standard right? I don't want any of these lol
North7
North Texas
SUV
Nice info but BN can go screw themselves with their stupid a$$ logo....
F$$k me...
Now that we were able to get the original document posted, it just shows, yet again, how ridiculous and nonsensical the Ford and Bronco Nation marketing partnership is. While Bronco6g is up to six pages of discussion of the, clean, readable spec we now have, the Bronco Nation "enthusiast" forum has three posts, that is 3 posts, not 3 pages of their unreadable document. Remember, BN is run by Jackson Dawson, Ford's marketing agency for the Bronco.
reidski29
Reid
Grand Rapids, MI
2013 Ford Expedition, 2018 Santa Cruz Blur
Roadside assistance is 3year/36 miles. Hmmm........
DustyBronco
Dusty
Woodbine, MD
FJ40
Was the 2.3L always rated at 300hp? I thought it was 270 stock and could be tuned up to 300?
edit: I see the other thread on this now...
Butzy
Butzy
Brookfield, Ohio
f150 & bronco
Badlands is 1" longer on 2dr and 4dr...?
I'm thinking wheel offset is different seeing how it also shows a wider stance, therefore the spare tire would stick out further though according to a chart i just looked at, the offset is showing the same with an 8" rim rather than 7.5......still doesn't calculate unless the sidewall pokes out an extra 1/2"
BTomorama
Atlanta, GA
2015 Nissan Rogue
I saw that shit yesterday and had a good chuckle :D.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
Wheel and tire specs including offsets:
Ford Bronco 2021 Ford Bronco Full Tech Specs 1620478992296
Toccoa
Isuzu Rodeo Sport
Found that odd as well. Maybe it’s the steel rear bumper? If it was the spare tire, the Wildtrak and FE would need to be longer as well.
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
Maybe my calculations are different but taking into consideration the difference in tire size...
Big Bend Tire Size (255/75R17=32.1") Difference of 2.3" from Wildtrak/Sasquatch tires.
Badlands Tire Size (285/70R17=32.7") Difference of 1.7" from Wildtrak/Sasquatch tires.
Wildtrak Tire Size (315/70R17=34.4")
2Dr Big Bend Height = 72.9" (2.3" shorter than Wildtrak)
2Dr Badlands Height = 73.8" (1.4" shorter than Wildtrak)
2Dr Wildtrak Height = 75.2"
2Dr Big Bend Height with 315/70R17 Tires = 75.2"
2Dr Badlands Height with 315/70R17 Tires = 75.5"
2Dr Wildtrak Height with 315/70R17 Tires = 75.2"
So according to my calculations, if we just changed the tires to the same tires as Wildtrak, Big Bend would be same height, Badands would be 0.3" taller???. That suggests to me the Wildtrak/Sasquatch suspension doesn't add height???
Sure the suspension may travel further, but it appears it doesn't get you height...
So I pulled diameters from Tirerack specs.
Big Bend Duelers: 32"
Badlands KO2s: 32.8"
Wildtrak Territories: no diameter listed so Duratrac as a proxy 34.4"
Those are diameters, which need to be converted to radius for difference in height between the hub and the ground.
Big Bend = 0"
Badlands = +0.4"
Wildtrak = +1.2"
Keep in mind here this is an estimate, since all tires flatten at the bottom of that lower radius, and while we can approximate they will flatter equally, the difference in recommended pressure and tire volume may have them flattening slightly differently. The only way to really know is to have three Broncos at OEM tire pressure on flat ground side by side and measure.
Anyway based on our approximation, if I subtract the tire radius differences from the heights:
Big Bend = 72.9"
Badlands = 73.8" - 0.4" = 73.4" or 0.5" higher than Big Bend
Wildtrak = 75.2" - 1.2" = 74" or 1.1" higher than Big Bend and 0.6" higher than Badlands.
BroncoRevital
Zak
Toyota Tacoma, past; 94 FB, 86 FB, 84 Bronco2
It still kind of blows my mind that this new “smaller” midsize Bronco is in some cases heavier then the 5G full size Bronco.
A 2d Badlands is 4877lbs and that’s not even Squatched! It doesn’t even have that heavy ass tailgate window motor or those lead back seats 😂
Username_not_found
Minnesota
Fiat 500 Abarth
Big Bend = 0"
Badlands = +0.4"
Wildtrak = +1.2"
Big Bend = 72.9"
This makes sense as it was stated previously that the Squatch does have an extra half inch on the badlands (ignoring tire diameter) when everyone was trying to figure out if the suspension on the badlands is identical to the Squatch package or not.
Burnsy949
Arthur
Orange County, CA
2013 JKU Rubicon, 2018 Volkswagen Golf R
Did anyone else notice that the 2 door has 4 gallons less fuel capacity than the 4 door? (About 19% less). That‘s significant. I had a 1973 Bronco so I know that “real Broncos have 2 doors” and all, but that’s important to know. I do a lot of overlanding so I’m going 4 door anyway, but it’s something to keep in mind. Range on trail will be affected.
