jaruss01
NJ
The mystery on length is the camera pole. It’s included. And the camera pole extends past all tire widths. So all configuration are the same length regardless of tire thickness.
BL maybe has an extra inch of length due to steel bumpers. I would expect the BD and FE to be the same, but they are not exclusively listed.
what else? Don’t see anything changed here.
-Looks like towing capacity suffers on heavier trims
-ford still forgot to include wildtrak 2.7 payload figures
-ford adjusted down the 2 door rear seat legroom by 0.6”. It not longer matches 4 door. This is probably just a marketing play and they found a ever so slightly different way to measure it for advertising purposes.
-most important (I don’t know if these numbers are different than before) but taller guys at the road show have been provided information from reps that you only lost 1” of headroom when the road show bronco is equipped with a hardtop. That ONLY true in the backseat. In the front seat where it matters you lose 2.5”
dgorsett
colorado
F250, Mustang, Explorer
Question on underbody protection: These specs detail underbody protection for various trims, good. There is no mention of Base, BB or OBX. I'm sure I saw somewhere 'bash plates' are on all trims, it's just a matter of how many and how tough. Anybody have info on the Base bash plates?
Smk9lvr
Gillian
Maine
Subaru Outback
Mid pkg has always been standard on BL, I also see the 110 AC has been bumped to 400 watts. And the 2.3 is confirmed as having vacuum boost brakes, which makes it much easier to add supplemental braking system.
I don’t believe mid package is standard, $1495.
KKCrunch
Delafield, WI
Ford Flex
Click here for the PDF version - Thank you @kellyweiss for the PDF version!
Sorry if this has already been asked. I just read this port for the first time. Does anyone know why they didn’t provide dimensional info for Outer Banks, Black Diamond, and First Edition ?
Lilj4425
Jacob
Greenville, SC
2021 Badlands Bronco
Did anyone else notice that the 2 door has 4 gallons less fuel capacity than the 4 door? (About 19% less). That‘s significant. I had a 1973 Bronco so I know that “real Broncos have 2 doors” and all, but that’s important to know. I do a lot of overlanding so I’m going 4 door anyway, but it’s something to keep in mind. Range on trail will be affected.
Where have you been the past six months?
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
Is it because those trims share the same specs as ones that are already listed? (So like OB and BD is the same as BB, FE is the same as WT?)
Mama_Dropt_Me
Minnesota
2016 Surbaru Outback
I like seeing the specs for the added roof rack on the four door, particularly with the wildtrak. Suggests that they are indeed going to release it at some point.
dgorsett
colorado
Auto Hold Brakes: Is this the hill start feature that prevents roll back when starting on a hill? I have a technique in the rocks to back out of throttle if I can't quite make an obstacle, let it roll back a bit and try again. I assume this will prevent that and require shifting to reverse?
Also interesting that 2.3 has vacuum assist brake and 2.7 has electric.
Monster1926
Indiana
GMC Sierra 2500HD
It’s similar. It works on flat ground also yo won’t have to hold the pedal down.
Bronco2021RV
Robert
Prescott Valley Az
Acura rdx
The dual port/direct injection on the 2.7 is a big plus. At a Bronco viewing last week I looked underhood and noticed that both of these engines use cooled EGR for emissions control. For the DI-only 2.3 that means the intake valves get hit with oil mist from the PCV AND cold exhaust from the EGR, with no means to rinse them off since there’s no fuel injection in the manifold. Anyone heard about how bad the intake valve buildup gets in rangers that have this 2.3 ecoboost with EGR?
Do you think an oil catch can would be much help with this problem?
colintrax
Georgia
Chevy Colorado, Ford Explorer, KTM 890 ADV
I think its an issue of the 2.3 not being explicitly designed for turbo use, and the 2.7 is.
So the 2.3 already rolls off the line with a vacuum pump and the 2.7 doesn't.
